| Forum topic by Neil Davis | posted 752 days ago | 1424 views | 0 times favorited | 7 replies | ![]() |
752 days ago |
Topic tags/keywords: question biscuit joiner veneering joining modern traditional I have seen a technique that is used on some table tops where the field is veneer plywood and the hardwood edge which is about 3 inches wide and mitered at the corners meets the plywood field with a decorative groove about 3/32 wide maybe as deep. What I want to know is how is the hardwood attached to the plywood. Will biscuits work in the plywood? And then also what is protecting the exposed edge of the plywood veneer top at the groove? Will the groove provide a place for the veneer to get snagged and peeled up or chipped? I have been looking for a close up example of this technique and most of the pictures of tables are at a distance to great to really see detail. |
7 replies so far
#1 posted 752 days ago |
as for the firs question biscuits will work in ply, the second is no the veneer will not peel or chip as long as the groove is a smooth cut. they put the veneer on at the factory and use a real good glue so this will not happen. -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
#2 posted 752 days ago |
I took such a table apart a while ago. It was better then 30 years old and made in Czechoslovakia. they used a spline in the hardwood ply and the ends. Damn good ply they made. -- When the moderator chooses sides, his site sucks. |
#3 posted 752 days ago |
and you guys are saying the veneer is staying glued down along the groove…...and not chipping or peeling? I would really like to build a big kitchen table using this method, but have been hesitant because of this very issue. I was even afraid of using the groove instead of a totally matched up joint with a good hardwood ply. I am encouraged by this discussion. thanks. |
#4 posted 752 days ago |
Biscuits will work. I am concerned about the exposure of endgrain in the substrate when that groove exists. Is it possible to make it a net fit? Just wiping the top down with a damp rag would be a negative, not to mention the upended tumbler (I just realized why they’re called that) of water. If you were to veneer the field yourself, you could edge the ply with 1/4” strips of your trim material and I’d sleep better at night. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#5 posted 752 days ago |
What a great suggestion, Lee. Edge the ply/veneer and then making the joinery. You are a wealth of knowledge and common sense. Thanks. |
#6 posted 752 days ago |
I was reading a really old Woodsmith magazine about edging plywood and they suggested cutting a spline into the edge of the plywood and then a groove into the hardwood edge. Do you think this would be a better way? I was recently using biscuits and had several of them installed into one edge and had glue on them, ready to install into the other edge and noticed that they had started to swell. Almost to the point of not being able to get them in the mating bicuit grooves. I was wondering if the hydraulic action of the moisture in the biscuit could potentially cause the plywood to split along plys causing a high spot on the ply top? |
#7 posted 751 days ago |
Neil - |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3551 |
15789 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6161 |
