Forum topic by blaughn | posted 03-17-2018 03:10 PM | 2011 views | 0 times favorited | 19 replies | ![]() |
I purchased a Grizzly 14” bandsaw (my first) and purchased a Lenox 3/4” Trimaster carbide tip blade to go with it. From the moment I installed the blade there was a visible runout (side to side deviation from center) no matter how much tension I put on the blade. Is this normal or should I send the blade back to be rewelded? -- Don't ever run out of airspeed, altitude and ideas at the same time. |
19 replies so far
#1 posted 03-17-2018 03:30 PM |
3/4” blades are too much for the 14” saw. The widest I use is a 1/2”. Carbide toothed blades require a HUGE amount of tension to work properly. -- bill@magraphics.us |
#2 posted 03-17-2018 04:41 PM |
↑agreed↑ That’s a lot of blade for the little fella. I do all my resawing with a 1/2” blade on a 14” Grizzly. |
#3 posted 03-17-2018 06:26 PM |
Whoa, a 3/4” Tri-Master on a 14” saw? I don’t think that a 14” has the strength for such a manly blade. I know what these blades cost >>per inch<<, but unfortunately I don’t think a 14” saw can tension a 3/4” Tri-Master. I had several 105”x 3/8” (var 3-4/in teeth) Tri-Master blades (acquired for $6 ea!, no kidding) for my 14” Delta-Milwaukee and they sliced through 10” of grenadillo wood easily with very little scoring – a wonderful blade. But they eventually broke long before they were dull—I think due to flexure and insufficient tension of the blade on the ‘small’ wheel diameter. I had them re-welded by a reputable commercial shop in the Detroit area (still a premier industrial town for small manufacturers), but they just didn’t work out. I wrote Lenox to ask for a factory re-weld but I never got an answer. -- Curator, Museum of Unfinished Projects |
#4 posted 03-18-2018 02:25 AM |
Oh phooy…. I run a 3/4” carbide blade on my Craftsman 14” bandsaw with no problem. I don’t get all this nay saying. |
#5 posted 03-18-2018 02:28 AM |
Ever used a Tri-mastet? -- Curator, Museum of Unfinished Projects |
#6 posted 03-18-2018 02:55 AM |
Find source of run-out. Is it at weld, or is blade have wave action? -- I'm an engineer not a woodworker, but I can randomly find useful tools and furniture inside a pile of lumber! |
#7 posted 03-18-2018 02:48 PM |
How thick is the body of the blade? As I recall, the 3/8 Tri was about 0.032, and regular blades are about 0.025. That increased thickness of 3/4” Tri might require more tension than your saw can do. If that’s the case, I wouldn’t be surprised if it wandered around. -- Curator, Museum of Unfinished Projects |
#8 posted 03-18-2018 08:45 PM |
Nope. I was commenting on the nay saying about using a 3/4” blade in general on a 14” saw. I’m currently using a 3/4” Laguna Resaw King. I see that the Tri-Master has quite a bit thicker backing than the Resaw King. |
#9 posted 03-18-2018 09:24 PM |
I’ll save my jingles for a Laguna. – the Tri-Masters are about $2/in these days, so I can’t afford to have them break prematurely.
#10 posted 03-18-2018 10:07 PM |
The Laguna Resaw King ain’t cheap. I’ve heard of people saying they’ve had those to break using a 14” saw. Knock on wood I’ve had mine for a few years and have used it a fair amount and it has hasn’t busted yet. |
#11 posted 03-18-2018 10:52 PM |
Thanks for all the input. The Tri-master just snapped (not at the weld) I am not inclined to spend another $175 on a blade that never worked correctly and broke prematurely. Will have think this through for a bit but Tri-master (of any size) will not me on my list in the future. Grrrrrrrrrr!! -- Don't ever run out of airspeed, altitude and ideas at the same time. |
#12 posted 03-19-2018 03:46 AM |
I had a 1/2 wide tri master on my 20 inch bandsaw one day it grabbed a odd shaped cut off and bent some teeth. -- Aj |
#13 posted 03-19-2018 12:52 PM |
“I had a 1/2 wide tri master on my 20 inch bandsaw one day it grabbed a odd shaped cut off and bent some teeth. I think these blades need a factory reweld and finish grinding if they break. When I got mine back from the commercial blade service, the joint and and performance didn’t seem the same at all. But overall, I think these Tri-Master blades are not a good choice for a 14” saw. -- Curator, Museum of Unfinished Projects |
#14 posted 03-19-2018 01:53 PM |
After the Tri broke, I used a 1/2” Timberwolf to finish the resaw. Though not as aggressive as the Tri, it does satisfactory work on resawing lumber. I think I will stick with throw-aways for awhile. My Scottish heritage won’t be as “unsettled” (to say the least) when one breaks. If I decide to return to a carbide tipped 1/2” blade for my 14” Grizzly (G0457), any recommendations based on personal experience? -- Don't ever run out of airspeed, altitude and ideas at the same time. |
#15 posted 03-19-2018 01:58 PM |
The Laguna Resaw King. It’s what I use on my 14” and have been happy with it. |
Forum | Topics |
Woodworking Skill Share
12027 |
Woodturning
2105 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4903 |
6693 |
28048 |
CNC Woodworking
211 |
Hand Tools
5405 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1387 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8844 |
