Belsaw 220v to 10v conversion
Forum topic by Weth posted 04-30-2011 09:52 PM 1510 views 0 times favorited 1 reply Add to Favorites Watch
View Weth's profile
57 posts in 2530 days
04-30-2011 09:52 PM
The belsaw manuals I have seen do not cover conversion of the unit from 220v to 110v.
Where can I get that info?
-- Weth
1 reply so far
View Loren's profile
10084 posts in 3579 days
#1 posted 04-30-2011 11:54 PM
You can’t generally run a motor over 2 hp on 110 volts. The Belsaw
planer motors are usually 3-5 HP.
If a motor is dual-voltage it usually says so on the information plate on
it and there is often a diagram under the wire access plate which
shows how to wire it for different voltages and sometimes in reverse.
Belsaw machines were often sold without a motor and the end
user would supply it.
You can put a less powerful motor on it if you like.
