Will a 110v 2HP paddle switch work for a Bosch 1617 (2.25 HP 120V)?
Forum topic by Winny94 posted 03-17-2018 01:01 AM 434 views 0 times favorited 5 replies Add to Favorites Watch
View Winny94's profile
Winny94
20 posts in 644 days
03-17-2018 01:01 AM
I need a paddle switch for my router table and this one has a lot of good reveiws, but the specs don’t line up with my Bosch 1617 – will this work?
https://www.amazon.com/dp/B005W17FRS/?coliid=I1C6GM8NW0UBFB&colid=3IP7JLY4GCPCR&psc=1&ref_=lv_ov_lig_dp_it
Also, how would I go about wiring this to a mobile table (i.e. needs to run on an extension cord and I’d prefer to keep the plug on the router cord as well so I can still use it handheld).
Thanks
5 replies so far
View WhyMe's profile
WhyMe
1073 posts in 1763 days
#1 posted 03-17-2018 01:55 AM
Absolutely that switch will be fine. I would wire it to control an outlet mounted on the mobile table for the router to plug into.
View CaptainKlutz's profile
CaptainKlutz
602 posts in 1697 days
#2 posted 03-17-2018 01:55 AM
If you do not want to wire up your outlet box for router table, why not use one of the router table paddle switches commercially available?
There are many companies that sell them if you look at Amazon.
Most are same made in china product with different labeling.
View Fresch's profile
Fresch
360 posts in 2123 days
#3 posted 03-17-2018 01:57 AM
Probably, is it really 2.5 hp? How many amps?
Get an inlet , you plug your xcord female into.
Get a receptacle, you plug your router male into.
Get 3 boxes that fit all your stuff.
Wire the inlet to the paddle switch (line side, hot)
Wire the recept. to the paddle switch (load side)
Done
View ArtMann's profile
ArtMann
1153 posts in 1019 days
#4 posted 03-17-2018 03:31 AM
That switch appears to be the exact same switch I am using for my router table. I use a 15A 3.25 hp Hitachi M12V router and it works great. I didn’t buy from Amazon. I got mine from Grizzly tools.
View jonah's profile
jonah
1926 posts in 3501 days
#5 posted 03-17-2018 04:03 AM
It will work fine. Switches are rated for certain voltage and amperage. Your router draws around 15A max. Any 15+ amp rated switch will work.
