Sealed Ball Bearing, or ?
Forum topic by bubinga posted 780 days ago 1520 views 0 times favorited 7 replies Add to Favorites Watch
View bubinga's profile
bubinga
860 posts in 864 days
780 days ago
Topic tags/keywords: question bandsaw ball bearing
What’s the difference between a sealed ball bearing, and a shielded ball bearing?
EDIT: Looking to replace band saw bearings
-- E J ------- Always Keep a Firm Grip on Your Tool
7 replies so far
View crank49's profile
crank49
2376 posts in 1168 days
#1 posted 780 days ago
A sealed bearing has rubber or other similar elastomeric seals that are fixed to the bearing and rub on the shaft.
A shielded bearing has metal labyrinth shields , like over-lapping washers, attached to the inner and outer races, but not actually touching each other.
The shielded bearing will have less friction, but is not as well protected from contamination.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
bubinga
#2 posted 780 days ago
crank49
Thanks
View karlhead's profile
karlhead
6 posts in 890 days
#3 posted 780 days ago
A sealed bearing is designed to seal against all contaminates especially liquids. whereas a shielded bearing is designed to prevent contamination from particulate matter.
View D_Allen's profile
D_Allen
495 posts in 981 days
#4 posted 780 days ago
Keep in mind that there are ‘cheap’ ones of both.
One main feature is the amount of lube they put into them.
Some I have seen seem to have had very little lube and go bad quickly.
-- Website is finally up and running....www.woodandwrite.com
View Minorhero's profile
Minorhero
102 posts in 802 days
#5 posted 780 days ago
I visit the old wood working machine forum (owwm.org) on a fairly regular basis. The folks on that forum are pretty much universally of the opinion that when replacing bearings on a machine it is always better to go with sealed bearings. I have done a handful of restores myself and followed this philosophy every time with only good things to say about sealed bearings.
View Grandpa's profile
Grandpa
2399 posts in 872 days
#6 posted 779 days ago
I agree that some bearings have more lubrication in them. I have seen this in a lot of areas especially in farm equipment. Ditto on the difference between the shileded and sealed bearings. I think I would go with the sealed if I could get them.
View swirt's profile
swirt
1864 posts in 1169 days
#7 posted 779 days ago
THanks for asking this Bubinga… all good information I am taking in here.
