Abrasivs for wooden pieces rock tumbling?
Forum topic by Bogdanovich posted 04-29-2011 08:03 PM 3286 views 0 times favorited 3 replies Add to Favorites Watch
View Bogdanovich's profile
Bogdanovich
120 posts in 2962 days
04-29-2011 08:03 PM
I had an order for the cubes of steamed beech 15×15x15mm http://lumberjocks.com/projects/47963. Easy to cut but when sanding started problems began. My wife is sand -of peaks of their fingers. After I post the project I got a suggestion to use a rock tumbler. I liked the idea and I found an old topic http://lumberjocks.com/topics/9848. There’s no machine like that here but it seems that it is relatively easy to make. Remains the question of abrasives. Neither of them out of stock here. It remains only patching with what is available. What to use: steel wool, pieces of paper for sanding, sand for Sand Blasting Machine or something else?
Please write if you have some experience, the idea (even seemingly stupid idea) or you just heard something about it.
Comments are most welcome.
-- My English and my woodworking are matching skills.
3 replies so far
View levan's profile
levan
472 posts in 3177 days
#1 posted 04-29-2011 08:50 PM
We tumble small pieces of beech in a hinged lid box, that is mounted on a metal lathe,turning at low speed. No abrasive, the sharp edges of the pieces does a very nice job. Try it you will like it. And it does not take very long.
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View JJohnston's profile
JJohnston
1622 posts in 3489 days
#2 posted 04-29-2011 09:01 PM
I don’t know if you can get cubes if you tumble. This project was done with a homemade vibratory machine. The pieces are rounded.
Click for details
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View mightywombat's profile
mightywombat
17 posts in 2784 days
#3 posted 04-29-2011 10:55 PM
Here is the video I was thinking of in my comment to your last post.
http://www.youtube.com/watch?v=jxMdqK_7Bh8&feature=youtube_gdata_player
It loos like just an improvised cylinder or maybe a large hole saw lined with some sort of sandpaper.
-- Make it, hack it, break it, fix it.
