Lubricate for Craftsman Model 351.221160 10" table saw
Forum topic by FlyBoy5 posted 03-14-2018 05:42 PM 359 views 0 times favorited 1 reply Add to Favorites Watch
View FlyBoy5's profile
FlyBoy5
3 posts in 193 days
03-14-2018 05:42 PM
Topic tags/keywords: question
It’s starting to take more force to raise or lower the blade. The gear on the end of the handwheel looks like nylon, delrin or some type of plastic.
Thanks
-- Jim, Ohio, http://www.WoodworkerJim.com
1 reply so far
View therealSteveN's profile
therealSteveN
1224 posts in 693 days
#1 posted 03-14-2018 09:51 PM
Likely it’s not the lube, rather a huge collection/jam of fine dust. I find softwood dust is stickier, but after a spell all of it can seize up you blade motion. I would suggest getting as much removed as possible (bare minimum is take out the blade insert, but if you can do it without a lot of effort taking off the top gets you right there.) to get in there. Using a toothbrush, and an air spray on a good compressor you can get it out, but you do need to do it several times. I should point out wearing goggles is a good idea, and keep your mouth closed. I actually use googles, and a face mask, under a face shield when I do this. Stuff goes everywhere.
For lube I look for the driest I can find. I like some of the bicycle lubes, but I DO NOT like anything with silicone in it to get onto my table. I find it really messes with the wood when it comes time to finish. I’m not sure if there is silicone in this or not, but instead of a spray, which most of them seem to be, this is drops. It allows me to put it “right” there. I do run the saw a bit before replacing the blade, and I hold a piece of cardboard down tight, because if it gets on the arbor it will fling it. I think that is actually when most get silicone on their table.
Finish line DRY Lube with TeflonĀ® fluoropolymer
-- Think safe, be safe
