Looking to make a sled jig
Forum topic by JTTHECLOCKMAN posted 03-14-2018 06:36 AM 362 views 0 times favorited 4 replies Add to Favorites Watch
View JTTHECLOCKMAN's profile
JTTHECLOCKMAN
226 posts in 3266 days
03-14-2018 06:36 AM
Not knowing where to put this I thought I would try here and if moderators need to move then that is OK.
I have a right tilt tablesaw and I am looking to make a sled to be able to cut staves accurately and repeatably They will probably be around 12” long. But they will be thin. Looking to probably make 6 to 8 staves per 1” diameter. So staves form a complete rod with a diameter of about 1” to 1-1/2” Would love to see others sleds if you have something like this. I do not want to have to set up a fence on the opposite side of the blade and keep moving it. With a sled I can make repeated cuts with maybe a stop block to set distance. Hope this makes sense. I can answer any questions if they come up. Thanks in advance.
-- John T.
View Woodknack's profile
Woodknack
12331 posts in 2496 days
#1 posted 03-14-2018 06:56 AM
If it splays in one direction, like a bucket, or forms a cylinder (what it sounds like), you can use a normal taper jig with the blade angled. I don’t have a picture of mine but they look like every other taper jig.
JTTHECLOCKMAN
#2 posted 03-14-2018 06:59 AM
If it splays in one direction, like a bucket, or forms a cylinder (what it sounds like), you can use a normal taper jig with the blade angled. I don t have a picture of mine but they look like every other taper jig.
- Woodknack
-- John T.
JTTHECLOCKMAN
#3 posted 03-14-2018 07:07 AM
It is not a compound angle. Straight angled cuts. What I am afraid of is the thin piece getting caught between table and blade and thus the piece will not be accurate. I was thinking of making a ramp for a lack of a better word so that the piece falls away from the blade. probably would have to raise the left side of the sled. I need to think this out and was hoping someone has done something like this. Whatever angle is needed to cut 6 to 8 pieces and form a perfect 1” to 1-1/2” rod of about 12” long. I glue together and put on a lathe to get exact dimension. I could make the diameter larger but do not want to get too large and waste wood. Will be wasting enough with blade kerf. Hope this is making sense.
-- John T.
Woodknack
#4 posted 03-14-2018 07:10 AM
Sleds for segmented woodturning do exactly that, only difference is your segments will not be tapered.
