Using a router as a planer
Forum topic by PhilLight posted 03-13-2018 01:55 PM 1073 views 1 time favorited 18 replies Add to Favorites Watch
View PhilLight's profile
PhilLight
12 posts in 373 days
03-13-2018 01:55 PM
I haven’t done it but I’ve seen the technique of using a router with a jig to flatten a large surface such as a workbench or tabletop or something like that. Can this same technique be used safely on end grain? A friend is needing to flatten a large round cut from a tree with a chainsaw. It is white oak and approximately 30 inches in diameter. He tried using a power plane on it and it destroys blades very quickly and efficiently. Is it likely to do the same thing to a router bit?
18 replies so far
View TheFridge's profile
TheFridge
10096 posts in 1603 days
#1 posted 03-13-2018 02:04 PM
People do it with end grain cutting boards all the time. As to what bits? Don’t know
View TechTeacher04's profile
TechTeacher04
389 posts in 1649 days
#2 posted 03-13-2018 02:19 PM
Any straight cutting bit will work, size depends on the router you have and the size of the work you are trying to flatten. Obviously a larger router can turn a larger bit and you can cover more ground quicker. It really depends on what you have at your disposal. Center cutting bits are not required as long as you can ramp you first cut or you can start the plunge off the stock.
View John Smith's profile
John Smith
1309 posts in 280 days
#3 posted 03-13-2018 02:27 PM
and ~ take small bites at a time.
several passes will give you less tearout other issues than one or two full passes.
the last couple of passes should be 1/8” or less.
you will be telegraphing the profile of the router sled to the stock you are working on.
so – your sled and router base must be as straight and accurate as possible
a hefty router (2-3hp) with 1/2” shank and very sharp 1” to 1-1/4” bottom bit will be fine.
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
View OSU55's profile
OSU55
1833 posts in 2106 days
#4 posted 03-13-2018 02:45 PM
It will work well on end grain, hard to get tearout (major issue with face grain). I think my bit is 2”, light passes to allow good control. Dont rush the cutting – trying to save time there after the time put into a slide, rails, and mounting makes no sense. It will leave lines between passes almost impossible to prevent. Sand or handplane to remove.
View UncleBuck's profile
UncleBuck
249 posts in 197 days
#5 posted 03-13-2018 03:27 PM
JUST BUILT A NEW ONE THAT WILL DO 6 FOOT X 24 INCH SLABS OLD ONE WAS WOOD ON WOOD THIS ONE HAS BEARINGS SO IT RUNS NICE USED POLY FOR THE ROUTER SLIDE. A LOT CHEAPER THAN THE WOOD WIZ THEY ARE HIGH PRICED.
-- Terry Uncle Buck Carvins "woodworking minus patience equals firewood "
View Drew's profile
Drew
350 posts in 3217 days
#6 posted 03-13-2018 06:08 PM
Infinity tools makes a router bit specifically for that.
Dado & Planer Router Bits
-- TruCraftFurniture.com
View AZWoody's profile
AZWoody
1396 posts in 1341 days
#7 posted 03-13-2018 06:18 PM
John Smith
#8 posted 03-13-2018 06:27 PM
wow, thanks Drew !! I just ordered the 1-1/2” bit. looks like it is pretty versatile.
View BoardButcherer's profile
BoardButcherer
144 posts in 211 days
#9 posted 03-13-2018 07:11 PM
- John Smith
I would have recommended the Amana myself. The replaceable blades are handy for leveling since you can find all kinds of trash in a large rough cut piece of wood like that. You can damage a bit on your first couple swipes and get stuck with a bunch of finish work or stuck waiting until a new bit arrives if you hit something big.
View Rich's profile (online now)
Rich
3527 posts in 706 days
#10 posted 03-13-2018 08:12 PM
I use one so often to flatten mesquite slices for trays and lazy susans, that I have my DW625 router dedicated to it with the bit always chucked up. For a bit, I went with the Freud 1-3/4” dia. bit (12-194). It cuts beautifully. and makes a huge mess in the shop.
My method is to simply locate the low spot on the board, set the bit to that depth, then give the adjustment a half turn (1/32”). Depending on the board, the cut depth can go 1/4” and beyond. Someone mentioned tear out, but I’ve experience absolutely none at all. Even deep pours of epoxy are no problem for this router/bit combo.
I’ve found that getting the optimal RPM is helpful. Too slow and the router tends to walk — even to the point of moving the sled on the bed — when the cutting gets deep. Naturally, with a bit that size, you don’t want to go too fast either.
View Firewood's profile
Firewood
440 posts in 1751 days
#11 posted 03-13-2018 09:01 PM
I built a sled for flattening slabs too wide for my 6” jointer. I put it on a pair of horses. One important step is to place a level on the sled over each horse and shim as needed to ensure you don’t plane a twist into your slab. Then shim the slab to make sure it’s stable during the routing process. I’ve had great success with this setup so far.
-- Mike - Waukesha, WI
PhilLight
#12 posted 03-14-2018 01:11 AM
I greatly appreciate the advice and the links. Now I have to figure out which bit I want. Thank you!
PhilLight
#13 posted 03-14-2018 01:37 AM
I just ordered the same one. :-)
- John Smith
View Drew's profile
Drew
#14 posted 03-16-2018 12:30 AM
- John Smith
- PhilLight
Glad I could help
View MrRon's profile
MrRon
4986 posts in 3360 days
#15 posted 03-20-2018 08:00 PM
I made a jig with two bed frame rails and a sled to flatten a 36×84 surface. Took time, but turned out good.
