| Forum topic by daveblev | posted 757 days ago | 1499 views | 2 times favorited | 14 replies | ![]() |
757 days ago |
ok, i’ve been reading posts where people are using ca to glue blanks onto a piece of scrap, then screwing that to a faceplate. are we talking about basic super glue, crazy glue, etc.? or is there a different ca just for woodworking? -- dave in s.e. ks. |
14 replies so far
#1 posted 757 days ago |
Yep, that is super glue. I would never use it myself for turning, soaks into the wood too much and does not hold strong enough in my opinion. I use turners double sided tape or regular wood glue if I am not in a hurry to turn the piece. -- Carpenter assembles with hands, Designer builds with brains, Artist creates with heart! |
#2 posted 757 days ago |
Pretty much CA is CA. The only real variation is thickness and additives. The thin stuff sets real fast. It’s like water. There is thicker, more gel-like CA that takes a bit longer to setup. You can get CA that is more flexible than the normal stuff. That’s about it. Brands matter a bit, but not much. Two common ones that are good are Zap and Bob Smith Industries. Often, the local hobby shop sells BSI under other names, but it says BSI on it. I use Loctite if I can’t get BSI or Zap. Loctite is fine, but you usually only find it in the smaller sizes and costs more per oz. Basic Crazy Glue will do. |
#3 posted 757 days ago |
is titebond good for this same purpose? the reason for the questions is that when i was turning years ago, about all we really had was carpenter’s glue. there’s just more stuff out there now, and i want to use what’s best! -- dave in s.e. ks. |
#4 posted 757 days ago |
One trick is to glue construction paper to the piece with yellow The glue is strong and the paper is too, but you can tear the CA glue is lousy at filling gaps, and it only makes a strong bond if |
#5 posted 757 days ago |
“Best”, now there’s a word. :) There are a lot of variables. In your original post, you didn’t mention the size of the ‘Blank’. For smaller blanks, I’m sure ‘Super Glue’ would work fine, but I wouldn’t use Thin. For gluing a dowel in place, I’d use the thin to soak into the wood. Alternatively, douse the hole AND the dowel with thin, then apply a tad of medium to the hole just before I installed the dowel. The combination of the thin AND the medium work together to get the best bond. For gluing a small blank to the scrap, I’d go with medium or thick(which I’ve never seen in the ‘Krazy Glue’ brand), but you’ll have to cut it off when you are finished turning. For a medium size bowl, I’d steer away from CA, it is too brittle and unpredictable on the vibrating lathe. Back to your original application. You’ll want a temporary bond. CA would not be my first choice unless your blank can be successfully sawn from the scrap. A better alternative to address the ‘temporary’ element might be to use white glue or titebond(I) with a piece of printer paper sandwiched between the blank and scrap. This can be successfully done with small to medium size bowls. If properly applied, hot melt glue could also be used. What I’m saying here is you may need to learn more about the properties of each glue choice. I’ve given you some things to consider, but maybe do some experimenting away from the lathe. I doubt there is EVER one “Best” glue for ALL lathe applications. There are always multiple aspects to consider, species, materials involved(metal vs. wood), strength of the joint needed, the shade of the wood, and many more. At a minimum, keep ahead of the safety curve, especially working with spinney chunks on the lathe. If you give us more information, then a better shot at a “Best” might be achieved. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#6 posted 757 days ago |
You haven’t mentioned dimensions ( H x D x W), type of timber or what yur are trying to achieve ( is this a bowl, platter or a hollow form or what)? -- Pete G: If you always do what you always did you'll always get what you always got |
#7 posted 757 days ago |
It has been my experience at the CA from Wal-Mart, etc. Does not hold nearly as well as the better grades available from places like Star Bomd, etc. There is a big difference in quality. -- Barbara |
#8 posted 756 days ago |
ok- -- dave in s.e. ks. |
#9 posted 756 days ago |
I was thinking of using CA glue just yesterday. -- When the moderator chooses sides, his site sucks. |
#10 posted 756 days ago |
CA bonds wood. It can create a very strong joint. It set’s very fast. The thin sets in a couple of seconds. The medium gel sets in 10 secs or so. That’s good if you want an instant set, usually not good when working with wood. We often want more, not less, set time. Note that it can take hours to get to a full strength joint, but you get a lot of hold quick with CA. CA is expensive per application relative to other wood glues. CA is hard to debond. If you can get at the joint itself, there are chemical debonders. Heat works, but you have to get the joint heated up pretty high, high enough that charring is a problem. A heat gun will work if you can get close enough. I don’t know much about extended life time. I think it’s very good. What happens to a CA bond over 100 years? Dunno. |
#11 posted 756 days ago |
As a turner, I use CA glue all of the time. Typically I use a two part commercial CA glue specially designed for wood working, 2P-10. It comes in several viscosities (thin to gel) and an activator. CA glue is applied to one face, activator to the other – you have about 8 seconds once the two pieces are put together with a full cure in about 10 minutes. Without the activator, the glue will still cure, but it takes much longer – giving you time to work with the joint if necessary. I have no problems using it to glue large turning blanks onto a sacrificial plywood faceplate, I use the method described above, i.e. a piece of paper between the blank and the plate, snapping the joint apart after turning with a wood chisel. Typically I use the gel CA for this application, which creates a very strong bond. I’ve never had joint failure using this method, even with very heavy pieces. Some things to note: 1. There is a big difference in strength and application between an industrial CA glue formulated for woodworking and the commercial stuff available in the big box stores. Both are useful, but you need to know the difference and limitations of each. The commerically available thin Titebond stuff, for example, is terrific for an inexpensive BLO/CA finish on pens, but I wouldn’t use it to bond blanks together. The cheap Titebond stuff is also available in 6oz bottles at most hardware stores and it’s terrific for bonding together hardboard, say if you’re making templates and jigs. I always keep a stock of hardboard (cheap, dead smooth and level, and easily machined or hand shaped, comes in a variety of thicknesses) and a dozen bottles of thin Titebond CA on hand for this purpose. 2. CA glue works best on wood if there’s a little moisture present. However, as noted above, CA glue has little shear strength. It is also inflexible. Practically what this means is: don’t use it to bond green wood, when the wood dries it will shrink and the glue joint will snap like a broken crystal. Don’t use it to bond joins that are expected to flex for the same reason. 3. Thin CA glue will soak into the wood, discoloring it. Areas of wood saturated with CA will not take stain, dye, or finish. This can leave the bottom of your turned bowl discolored if you use the glued sacrificial plate mounting method. A gel CA reduces this problem. A CA joint will leave a thin black line between pieces, this isn’t always a bad thing, depending – here, for example: http://lumberjocks.com/projects/38053, I used CA to bond together the pen blanks and the black line helped define the design. A gel CA combined with powdered stone, metal, or sawdust, makes a good inlay filler for turned pieces. 4. Don’t use CA glue to join end grain unless the joint is non-load bearing and reinforced (like those pens above, those are end grain to face grain joins, but the wood is stablized and the blank is really held together by the pen tube in the middle). 5. CA does not expand. As noted above, you can’t use it to fill in wood, unless you use it as a bonding agent for a filler material, like sawdust. If you do this, remember, the resulting fill won’t take finish. This can be a useful property, or a pain, depending. I make a filler from damp used coffee grounds and thinset CA for spalted wood. Works great and looks beautiful and blends perfectly into spalted birch for example, but you have to work fast because the moisture in the grounds will cause the CA to start setting almost instantly. 5. CA cures much faster in moist wood. It will generate heat (in the coffee ground fill application, it generates a LOT of heat and steam, enough to burn you) during the curing process and give off poisonous vapors similar to tear gas. You don’t want to breath the vapors, seriously. 6. If you work with CA a lot, say if you’re making pens, buy a 3-pack of those 100-pair boxes of vinyl gloves from your local wholesale store. The minor expense is worth not having that crap all over your fingers. I go through a couple hundred pairs of those things a month in my shop. Hope that helps. //Jim -- Jim Wright, Stonekettle Station |
#12 posted 756 days ago |
I glue blanks to waste wood often. I’ve never had a problem with it flying off. Advice – Before doing the gluing shape the surface of the waste wood with a very shallow concave. Then you are certain to have solid contact at the edges. Then apply glue only at the edge – all the way around. If you have perfectly flat surfaces and glue the whole surface, you will never get the waste block off. With my approach you can usually get it off with a hammer/mallet and chisel. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#13 posted 756 days ago |
all very interesting reading! -- dave in s.e. ks. |
#14 posted 756 days ago |
Great info Stonekettle. I would observe a couple of things: 2. Acetone will debond CA. They have special debonders, but in a pinch use acetone. It works on fingers glued together (don’t ask me how I know). 3. The C in CA is Cyanoacrylate. The cyan in cyanoacrylate is cyanide. That’s what’s in the fumes. Nasty |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1536 |
3554 |
15803 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
