Very early stanley handplane, Frog won't come off.
« back to Hand Tools forum
Forum topic by Johnalan Thomas posted 03-11-2018 11:27 PM 665 views 0 times favorited 8 replies Add to Favorites Watch
View Johnalan Thomas's profile
Johnalan Thomas
57 posts in 1092 days
03-11-2018 11:27 PM
Topic tags/keywords: stanley plane screw help restoration
Hey Y’all, Picked up a very early 1910’s Stanley #5 for 6 bucks at a flea market yesterday. It’s extremely rusted.
I cannot get one of the screws out to take the frog off. It bends my screwdrivers. I have it soaking hopefully it will loosen the screw-up. Does anyone have any ideas on how to get this screw out? Thanks
-- John Darlington Sc
8 replies so far
View Loren's profile
10477 posts in 3845 days
#1 posted 03-11-2018 11:56 PM
Soaking it is the best approach I think.
PB-Blaster is good if what you have isn’t
doing the job.
It’s possible to heat up a stuck screw with
a propane torch and the expansion can help
to loosen it. I did this once on a sewing
machine. I got the screw out finally but the
slot was damaged.
View Johnny7's profile
Johnny7
393 posts in 1288 days
#2 posted 03-12-2018 01:13 AM
Patience, my friend, is rule no 1 for freeing rusted or otherwise frozen parts.
View Tim's profile
Tim
3812 posts in 2159 days
#3 posted 03-12-2018 05:41 PM
What are you soaking with? a 50/50 mix of acetone and automatic transmission fluid is apparently more effective than other penetrating fluid.
I agree with patience. Soak it long enough and you won’t need to do much more.
If patience wears out, first step is to grind a screwdriver to perfectly fit in the slot (as close to zero slop as possible) with a hollow grind so the turning force is at the very bottom of the slot. Try that, then try tapping the driver end with a hammer to loosen the rust’s hold, then try tapping as you turn. A manual impact driver with a tight fitting bit could work.
The problem with heat from a torch on a frog bolt is you’ll burn off any japanning that is left around there. I’d only do that if the japanning was already shot on both the sole and the frog.
View corelz125's profile
corelz125
565 posts in 1174 days
#4 posted 03-12-2018 07:47 PM
a soak in evapo rust helps
View simmo's profile
simmo
69 posts in 3669 days
#5 posted 03-12-2018 09:27 PM
Freezer spray
View Don W's profile
Don W
19007 posts in 2765 days
#6 posted 03-13-2018 12:51 PM
If soaking doesn’t help….heat
http://www.timetestedtools.net/2016/01/27/saving-a-stanley-type-2-risk-equals-reward/
View Just_Iain's profile
Just_Iain
291 posts in 614 days
#7 posted 03-14-2018 01:59 PM
Drop it in whichever ‘solution of your choice’ and wait at least a week. ” It’s extremely rusted.” is a strong hint not to rush.
-- For those about to die, remember your bicycle helmet!
View squazo's profile
squazo
111 posts in 1843 days
#8 posted 03-14-2018 03:41 PM
Soak it, in an ultrasonic cleaner. Or on something that vibrates all day like an engine. A machine shop will probably do it for 30 bucks. I do that all the time.
