Advice on replacing Jet JWBS-14CS bandsaw items
Forum topic by kanihoncho posted 04-27-2011 04:03 AM 4711 views 0 times favorited 5 replies Add to Favorites Watch
View kanihoncho's profile
kanihoncho
56 posts in 3038 days
04-27-2011 04:03 AM
Topic tags/keywords: jet jwbs-14cs bandsaw upper wheel shaft hinge tensioner heavy duty spring carter iturra
Has anyone replaced their upper wheel shaft hinge with a product from another company? Jet only sells the whole assembly for over $100. I just need the hinge part that moves the upper wheel to center the blade. It is bent like crazy. I can get the entire assembly from Grizzly for 12 bucks. I’m also seeing that RIDGID and Delta parts might work as well.
I am also looking into the tensioner as it has stripped. I am looking at:
1. Carter accuright ratchet rod
2. Iturra step 2 tension adjuster
as well as a new heavy duty spring
Any help and useful experience tips are appreciated. Many thanks.
5 replies so far
View Steven H's profile
Steven H
1117 posts in 3025 days
#1 posted 04-27-2011 04:32 AM
If your bandsaw still in warranty, they will send it to you for free.
View Mickey Cassiba's profile
Mickey Cassiba
312 posts in 2996 days
#2 posted 04-27-2011 04:54 AM
In the world of mickey-rigging a BS degree in ‘oughta-fit’ is necessary. No way to know, without holding up both parts together and looking. I do know that the elevating rack gear from a delta drill press will fit a ridgid. Never tried any bandsaw parts though.
-- One of these hammers oughta fix that...
View mchuray's profile
mchuray
81 posts in 2963 days
#3 posted 04-27-2011 05:13 AM
Check out the Shop Fox 14”. As far as I can tell ,except for the ball bearing guides, they are almost identical.
Mark.
kanihoncho
#4 posted 05-05-2011 03:34 PM
I took a chance and ordered the hinge from Grizzly for $12. Perfect fit and same exact part number stamped on the part as the Jet parts diagram indicated.
View tenontim's profile
tenontim
2131 posts in 3709 days
#5 posted 05-05-2011 04:06 PM
Louis Iturra makes nice after market parts for the 14” bandsaws. I think this is current info
Iturra Design
1-866-883-8064
