One-at-a-time drawers?
Forum topic by William Shelley posted 03-11-2018 10:25 PM 1163 views 0 times favorited 23 replies Add to Favorites Watch
View William Shelley's profile
William Shelley
576 posts in 1588 days
03-11-2018 10:25 PM
Sorry I don’t know how else to title this post.
What I’m looking for is a mechanism, either commercial or something I can make, that will only allow one drawer to be pulled open at a time, from a cabinet.
I’d like to build a cabinet for organizing a large collection of trading cards, which are extremely heavy when packed densely in drawers. So to prevent tipping, it would be good if only one drawer could be pulled out at once with some kind of passive lock that would prevent the others from opening. Each drawer might weigh 150lbs when fully loaded.
Of course, the other (simpler?) option is to just provide a place at the back inside of the cabinet carcass that could be fastened into a stud in the wall. That’s my fallback plan.
-- Woodworking from an engineer's perspective
23 replies so far
View John Smith's profile
John Smith
1310 posts in 281 days
#1 posted 03-11-2018 10:31 PM
it is good that you are thinking of this safety feature now.
personally – something of that size and weight should be bolted
to the wall studs – no second guessing it.
after you get it all built and in place, a warning sticker would also be advisable.
also – keep it locked – then you can control access to it as well as when.
but, with the proper pre-planning, the bolts will be inside the carcass and not seen.
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
William Shelley
#2 posted 03-11-2018 10:33 PM
- John Smith
Ok, good point. For this project I will make it bolt-able to the wall. However, for the sake of academics, lets keep this thread going. What would the mechanism look like to provide this auto-locking feature?
View CaptainKlutz's profile
CaptainKlutz
454 posts in 1613 days
#3 posted 03-11-2018 10:54 PM
There are several patents regarding “one at a time” mechanisms. Most are custom designed and installed into finished cabinets.
Only know/used one brand sold commercially:
Accuride has #3641 system
Spoke too soon (Dr. Google found another option)
Fulterer also sells FPS 8000 Locking Anti-tilt System for use with their slides.
YMMV
woodbutcherbynight
5545 posts in 2528 days
#4 posted 03-11-2018 11:19 PM
Simpler solution much easier to do and materials are readily available. Put a keyed lock on each drawer.
View Rayne's profile
Rayne
1026 posts in 1658 days
#5 posted 03-12-2018 12:42 AM
Maybe you could do some kind of lever system. One lever lifts up and unlocks all the drawers, open one to cross the lock mechanism threshold, then release lever to lock the remaining drawers.
View splintergroup's profile
splintergroup
2253 posts in 1341 days
#6 posted 03-12-2018 07:02 PM
Most cheap file cabinets have this feature. Check out a small 2-drawer file cabinet at Walmart or wherever to see how they do it.
View Loren's profile
10477 posts in 3767 days
#7 posted 03-12-2018 07:11 PM
Something like a pair of shaped tabs sticking
out the back of each drawer. When one tab
is pulled from the hole in a bar, a linkage of
some sort causes a second bar to drop down,
engaging the other set of tabs in the rest of
the drawers.
Dunno. Sounds like either a hassle or a fun thing
to make.
View BoardButcherer's profile
BoardButcherer
144 posts in 213 days
#8 posted 03-13-2018 01:54 PM
This company owns a patent, but more importantly they have a video on their website showing someone building the mechanism by hand. If you’re feeling savvy you could try to copy it.
View Jon Hobbs's profile
Jon Hobbs
147 posts in 823 days
#9 posted 03-13-2018 06:22 PM
- woodbutcherbynight
What would stop someone from unlocking multiple drawers and opening them?
-- Jon -- Just a Minnesota kid hanging out in Kansas
View caboxmaker's profile
caboxmaker
281 posts in 507 days
#10 posted 03-13-2018 06:28 PM
The best idea is the bolt it to the wall.
John Smith
#11 posted 03-13-2018 06:29 PM
if the cabinet is SECURELY bolted to the wall studs – that will prevent it from tipping over.
Jon Hobbs
#12 posted 03-13-2018 06:34 PM
- John Smith
Absolutely! However, the suggestion I was inquiring about was to put a keyed lock on each drawer. I was hoping woodbutcherbynight could clarify how that would solve the OP’s problem. Based on what I know now, there are other, better options, such as bolting it to the wall. But I’m open to learning new tricks…
View DS's profile
DS
2978 posts in 2539 days
#13 posted 03-13-2018 06:42 PM
Compx Timberline has a lateral file gang lock that you can add a wedge to that prevents more than one drawer at a time from being opened. It is an anti-tip feature.
When you open a drawer, the wedge activates the locking bar for the other drawers until it is closed.
BoardButcherer
#14 posted 03-13-2018 08:11 PM
- DS
I find it highly amusing that the two patents you and I have linked are essentially the same device, just reversed.
Mine has the peg on the drawer, yours has it on the cabinet.
View MalcolmLaurel's profile
MalcolmLaurel
298 posts in 1742 days
#15 posted 03-13-2018 10:42 PM
- Jon Hobbs
Keyed alike, one key, can’t remove the key unless locked.
-- Malcolm Laurel - http://MalcolmLaurel.com
