Glue or Epoxy?
« back to Joinery forum
Forum topic by docspencer posted 03-11-2018 08:45 PM 443 views 0 times favorited 11 replies Add to Favorites Watch
View docspencer's profile
docspencer
362 posts in 1973 days
03-11-2018 08:45 PM
I’m building a cherry bench with slab top and slab legs. I’m using dowels to join the top to the legs and stretcher to the legs. The dowels are a bot loose in the holes. Will glue be strong enough or should I use epoxy. This is my first piece to sell so I want it to be good and sturdy. Thanks.
11 replies so far
View BFamous's profile
BFamous
133 posts in 148 days
#1 posted 03-11-2018 08:54 PM
If the dowels are loose, switch to bigger dowels. Sure you could use a liquid that expands to hope the gaps are filled, but wouldn’t you feel better knowing you sold a piece where the joints were tight to begin with?
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
View eflanders's profile
eflanders
301 posts in 1878 days
#2 posted 03-11-2018 08:54 PM
An epoxy would probably be best because of the loose fit. Otherwise use a gap filling/expanding glue like gorilla glue.
View bondogaposis's profile
bondogaposis
4769 posts in 2379 days
#3 posted 03-11-2018 08:58 PM
Use wedges in the dowels to tighten the fit. It is always better to have a strong mechanical bond than to rely on glue to compensate for a weak one.
-- Bondo Gaposis
docspencer
#4 posted 03-11-2018 09:01 PM
Wow. Thanks for the quick replies. I should clarify – used 3/4” dowels and 3/4” forstner bit. The dowels wouldn’t fit so I had to sand a bit. Not horribly loose but I wanted to create room for the glue/epoxy.
View Woodknack's profile
Woodknack
11813 posts in 2407 days
#5 posted 03-11-2018 09:08 PM
Or wedge the dowel.
View Loren's profile
10476 posts in 3675 days
#6 posted 03-11-2018 09:47 PM
Dowel rod sold in hardware stores isn’t round.
If you’re getting your dowels from that material
I recommend re-thinking the approach.
Round dowel stock can be made with a jig on
the table saw or with a router table.
BFamous
#7 posted 03-11-2018 10:27 PM
Well if you sanded them too thin, can’t you just get new ones? :)
Otherwise, I agree with the wedged approach too.
docspencer
#8 posted 03-11-2018 10:38 PM
Sure. I have some of the rod left. Don’t I need some room for adhesive in the hole?
View Rich's profile
Rich
3009 posts in 617 days
#9 posted 03-11-2018 10:55 PM
How loose are they? If there are no big gaps and the dowel holds on its own, just use some PVA glue.
View TheFridge's profile
TheFridge
9608 posts in 1513 days
#10 posted 03-11-2018 11:12 PM
If you have an 1/8”+ thick pc of steel you can make a dowel plate.
Drill a hole. Pound it through. I did some 1/8” dowels recently. Worked like a champ.
View patcollins's profile
patcollins
1685 posts in 2892 days
#11 posted 03-12-2018 01:32 PM
Many dowels that are made for the purpose of joinery are fluted so that the glue has a place to go when you pound them in. If there is no place for the glue to go the dowel will not go in all the way. If I were making my own dowels I would take a triangular file and make some small random notches on them for the glue to go.
