Metric to English dust collector fittings
Forum topic by Sark posted 03-11-2018 04:30 PM 957 views 0 times favorited 2 replies Add to Favorites Watch
View Sark's profile
Sark
74 posts in 481 days
03-11-2018 04:30 PM
My 2 hp dust collector has 120mm ports or about 4.75” . I bought a Dust Deputy separator which has an exhaust port of 6” . So I need to go from 120mm to 6” . I’ve jury rigged adaptors before but would rather have something off the shelf if it exists. Thanks for your help.
2 replies so far
View therealSteveN's profile
therealSteveN
1237 posts in 695 days
#1 posted 03-24-2018 04:10 AM
“I would try a 6” to 5 Fernco coupling.
The 6” would fit, and the 5” would easily draw down 1/2” or so. You can flow water through them, so some dust should be pretty easy work. Plus they aren’t sell the house kind of expensive.
-- Think safe, be safe
View John_H's profile
John_H
176 posts in 1827 days
#2 posted 03-24-2018 05:12 AM
I believe that most of the ‘European’ woodworking equipment uses 120 mm ports. My sliding tablesaw does. A 4” Fernco is a pretty good fit OVER the 120 mm port – so I would think you would need something like a 6” reduced to 4”.
Here is what I am using
https://smile.amazon.com/gp/product/B000BQQU52/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Take a look at this 6” x 4”
https://smile.amazon.com/Fernco-P1056-64-6-Inch-4-Inch-Coupling/dp/B000BQM0JC/ref=sr_1_2?s=hi&ie=UTF8&qid=1521868322&sr=1-2&keywords=fernco+6
