Miter slots
Forum topic by TimInIndiana posted 03-10-2018 03:14 PM 475 views 0 times favorited 10 replies Add to Favorites Watch
View TimInIndiana's profile (online now)
TimInIndiana
87 posts in 162 days
03-10-2018 03:14 PM
Some table saws have T-style miter slots and others have flat miter slots (please pardon me if I’m not using the correct terms here!). What are the advantages of one of the other? I would imagine that T slots make it more difficult to use after-market accessories.
10 replies so far
View Sunstealer73's profile
Sunstealer73
166 posts in 2115 days
#1 posted 03-10-2018 03:29 PM
Even with the t-slots, you can still use accessories for regular ones. The advantage is that if you need to use for example your miter gauge to crosscut a wide panel, you can start it off the table and the t-slot will keep in place for you.
View bondogaposis's profile
bondogaposis
4755 posts in 2373 days
#2 posted 03-10-2018 03:49 PM
It makes no difference, you can use the t-slots or not.
-- Bondo Gaposis
View Kelster58's profile
Kelster58
670 posts in 562 days
#3 posted 03-10-2018 03:54 PM
The t-slot holds the miter gauge in place while you are getting the cut started or cross cutting a very wide piece.
-- K. Stone “Tell me and I forget, teach me and I may remember, involve me and I learn.” ― Benjamin Franklin
View splintergroup's profile
splintergroup
2071 posts in 1245 days
#4 posted 03-11-2018 02:33 PM
T-slots are more of safety feature, but generally standard on larger saws. They should not interfere with accessories and actually provide a way for stuff to clamp down to the table surface.
T-slot miter gauges will cause problems when you forget to cut wide enough slots into your out feed table 8^)
View AxkMan's profile
AxkMan
65 posts in 149 days
#5 posted 03-13-2018 12:03 AM
Keep in mind T-slots are useful if you want to make a tablesaw sled. If you have two T-Slots that is. Most tablesaws should come with two with one on either side. Your width usually makes most of the difference being the length of boards you will be crosscutting.
For a tablesaw sled you buy 2 rails from the manufacturer and attach to the bottom of your sled. Very useful for accurate crosscuts on tablesaws. Without the rails, really too much of a hassle for a sled.
Of course I don’t use tablesaws for crosscuts that much. I mainly use tablesaws for ripping. I prefer to use the Miter Compound Saw for crosscuts more than a tablesaw. More accurate when used with a precision blade on it and almost flawless. The only drawback is in wider boards beyond the allowed limit.
View Rich's profile
Rich
2962 posts in 612 days
#6 posted 03-13-2018 12:34 AM
Of course I don t use tablesaws for crosscuts that much. I mainly use tablesaws for ripping. I prefer to use the Miter Compound Saw for crosscuts more than a tablesaw. More accurate when used with a precision blade on it and almost flawless. The only drawback is in wider boards beyond the allowed limit.
- AxkMan
If you do cabinet work, a crosscut sled with at least a 28” capacity is pretty handy to have.
woodbutcherbynight
4824 posts in 2431 days
#7 posted 03-13-2018 03:49 AM
- Rich
I want to make one, and just as soon as I figure out where I will store it I plan on making one. Frankly if I had it to do all over again I would buy 3 acres of land, a single wide trailer and build a 10,000 sq ft shop. This way the space issue would have never been a problem. Oh and skipped getting married to the 1st wife…..
ROFL
View Rich's profile
Rich
#8 posted 03-13-2018 04:39 AM
ROFL
- woodbutcherbynight
They’re flat, so you’ll only need maybe 5000 sq ft. My dream here in AZ is a triple-wide on 100 acres in Avra Valley with a berm to shoot into from 25, 50 and 100 yds, and a double-wide for my shop. I’d go for some horses, but I’ve had too many sad times losing them.
Just a first wife? You’re a lucky guy.
woodbutcherbynight
#9 posted 03-13-2018 05:20 AM
I learned a few things from first failure. This is much better to come home to every night!
View Kelly's profile
Kelly
2039 posts in 2966 days
#10 posted 03-13-2018 05:45 AM
A T slot can be used for certain clamping devices. The washer pulls up against the iron and locks the jig or what have you in place.
