Lateral Adjustment Lever, and an Unrelated Bonus Question
Forum topic by CharlieM1958 posted 04-26-2011 04:57 AM 1528 views 0 times favorited 16 replies Add to Favorites Watch
16272 posts in 4126 days
04-26-2011 04:57 AM
I’m currently rehabbing a Stanley #3, and I noticed the lateral adjustment lever is extremely tight. It works, but moving it from side to side is a real effort. Do any of you hand plane experts know a trick to loosen it up a little, without making it too loose?
By the way, in case anyone noticed my absence last week, I was on a combination business conference/pleasure trip. Ten bonus points to anyone who can name all three California cities where these photos were taken:
http://www.flickr.com/photos/68271167@N00/sets/72157626452803749/show/
16 replies so far
13594 posts in 3249 days
#1 posted 04-26-2011 05:18 AM
carmel
monterey
san francisco
View majeagle1's profile
majeagle1
1426 posts in 3404 days
#2 posted 04-26-2011 05:38 AM
Well, I think Patron nailed it…... a day late and a dollar short !
Hope you enjoyed your trip, you hit some of my favorite areas !
-- Gene, Majestic Eagle Woodworks, http://majesticeagleww.etsy.com/, http://www.flickr.com/photos/majesticeagle/
View whitedog's profile
whitedog
652 posts in 3365 days
#3 posted 04-26-2011 05:45 AM
Monterey … I was there last week also on Tues. , some beautiful days last week. We had people from Australia here so we took them on 17 Mile Drive. Next time your here let us know.
-- Paul , Calfornia
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6940 posts in 3342 days
#4 posted 04-26-2011 05:45 AM
Carmel by the sea
San Fran
Big Sur or Monterey
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
View ksSlim's profile
ksSlim
1271 posts in 2798 days
#5 posted 04-26-2011 06:07 AM
Try a shot of PB Blaster to loosen your lateral lever. Blaster is usually available in auto parts stores.
-- Sawdust and shavings are therapeutic
View WayneC's profile
WayneC
13751 posts in 4005 days
#6 posted 04-26-2011 06:42 AM
I would hit the lateral adjuster with a little 3 in 1 oil. Not tried Blaster.
View bubinga's profile
bubinga
861 posts in 2575 days
#7 posted 04-26-2011 08:00 AM
I had one like that ,It was real bad, I shot it with WD-40, work back and forth, still tight, put 3n1 oil on it, and Kept working it back and forth, put more oil on, and back and forth, I did this a lot, and it finally loosened up enough to be acceptable.
Maybe it loosened up from all the friction and heat !!!
-- E J ------- Always Keep a Firm Grip on Your Tool
#8 posted 04-26-2011 03:48 PM
David, you took all the suspense out of it. !0 points to you!
Thanks for the advice guys. Looks like a little lubrication and continued movement will be my course of action.
View TheDane's profile
TheDane
5367 posts in 3571 days
#9 posted 04-26-2011 05:03 PM
Charlie—”... lubrication and continued movement …” is a good prescription for lots of stuff. My grandfather lubed himself with a couple of shots of Schnapps every day, than took a long walk in the park. He lived to be 93!
—Gerry
#10 posted 04-26-2011 05:21 PM
hey
i had to move fast
the next 4 guys
were chafing at the bit
to be first
i hope the 10 points
are
‘thou can’
not more of that
‘thou can’t’
#11 posted 04-26-2011 05:22 PM
Gerry: Sounds like a plan! I can’t do that kind of lube anymore, so I guess I’ll have to double up on the movement part. :-)
View ptweedy's profile
ptweedy
75 posts in 3301 days
#12 posted 04-26-2011 05:25 PM
carmel yes not monteray, Pacific grove, San Francisco phil
#13 posted 04-26-2011 06:27 PM
Hey Phil…. okay, I think we’re splitting hairs, but technically you are 100% correct. Pacific Grove… not Monterey.
Sorry David, I’m going to have to take back the 10 bonus points and give them to Phil. :-)
View Dan's profile
Dan
3630 posts in 2788 days
#14 posted 04-26-2011 08:26 PM
Charlie- Oil and side to side movement will probably fix it but if it still seems tight after that you can also try slightly bending the lever back and forth in the opposite. If it comes to that I would use some vise grips and wiggle it close to the pin where it is attached to the frog.
-- Dan - "Collector of Hand Planes"
CanadianWoodChuck
402 posts in 3821 days
#15 posted 04-27-2011 01:05 AM
Charlie – I don’t know anything about hand planes but it was nice to see you took your daughter along on your trip – great bonding :)
-- Wood Chuck (Bruce) http://3dwoodworkingplans.com
