1/4 spalted veneer
Forum topic by Bruce Martens posted 03-10-2018 06:12 AM 332 views 0 times favorited 6 replies Add to Favorites Watch
View Bruce Martens's profile
Bruce Martens
15 posts in 110 days
03-10-2018 06:12 AM
Topic tags/keywords: question maple veneering
Hi, I have some 1/4 inch spalted and figured bandsaw slices. I want to use them book-matched as the surface of some coffee tables but I am concerned that if I glue a thick slice of like this to plywood it will move and the plywood won’t. It is fairly solid but a bit punky/crumbly in some small areas so may not stay intact if I try to thin it to veneer thickness.
If I epoxy or glue it to plywood first and then sand it down to 1/8” will that be problematic?
Also I would appreciate any suggestions of how to handle the edge profile since it would need to be irregular. I think I would have to trim it close to the live edge and round at the ends.
-- It's not the mistakes you make that matter, it's the mistakes you leave.
View TheFridge's profile
TheFridge
9606 posts in 1509 days
#1 posted 03-10-2018 06:48 AM
Yeah that’s on the thick side. I’d contact LJ shipwright. A wealth of veneering info.
View Rich's profile (online now)
Rich
2963 posts in 612 days
#2 posted 03-10-2018 06:54 AM
Since your veneer is crosscut, there should be less movement. However, Fridge makes a good suggestion to see what shipwright thinks. Beautiful stuff, BTW.
View shipwright's profile
shipwright
7992 posts in 2821 days
#3 posted 03-10-2018 06:52 PM
You are falling just a little between the cracks of my experience. I am first and foremost a boat builder and my experience there says that an overlay like a teak over plywood deck can be glued down with epoxy up to about 1/8” of teak thickness. Thicker should be glued with a flexible compound like Sikaflex or Thiokol to account for possible shrinkage and swelling.
My veneer experience doesn’t go as thick as 1/4” so I don’t have any first hand knowledge to pass on there.
However, I would think that if you apply it with any good glue (personal choice hide glue) and sand it down to 1/8”, you should be fine. The better you protect it from atmospheric moisture the less you have to worry about but I think you should be fine.
View WyattCo's profile
WyattCo
86 posts in 127 days
#4 posted 03-10-2018 09:58 PM
There’s not going to be a lot of movement at 1/8” thick. However, creep can still be a problem. Hide glue will be your best friend.
Bruce Martens
#5 posted 03-11-2018 01:55 AM
Thanks everyone, sounds like there are a couple of ways to go with this but I might try attaching it with epoxy to plywood, using a thickness sander to bring it down to 1/8” and then flooding it with thinned epoxy to stabilize it because I think this stuff will suck it right up.
shipwright
#6 posted 03-11-2018 02:17 AM
That should work very well. The best penetrating epoxy to use would be IMHO System Three S1 sealer. I have used it for years and it really excells at penetrating and hardening. This is particularly important if the spaulting has advanced to soften the wood. You can recoat with it as a finish or use a bar top epoxy or really anything else over it.
