Dowel size for breadboard ends, is 1/4” big enough.
« back to Joinery forum
Forum topic by BaltimoreChris posted 03-09-2018 11:41 PM 774 views 0 times favorited 9 replies Add to Favorites Watch
View BaltimoreChris's profile
BaltimoreChris
4 posts in 241 days
03-09-2018 11:41 PM
Trying my first breadboard ends. The end board (breadboard end) is about 3.5 inches deep and 5 tenons stick out of the man table about 1 1/8”. Would 1/4” dowels be large enough to secure the breadboard ends or should I use 5/16” dowels?
9 replies so far
View LesB's profile
LesB
1802 posts in 3564 days
#1 posted 03-10-2018 12:37 AM
A pair of 1/4” in each Tenon will work, 5/16 better and I would even go 3/8”.
-- Les B, Oregon
View Rich's profile (online now)
Rich
3551 posts in 710 days
#2 posted 03-10-2018 07:06 AM
You probably don’t need 5 tenons. If you leave a half-inch or so along the full length and make a slot in the breadboard, you should be good with a center tenon and one on each end.
View HammerSmith's profile
HammerSmith
137 posts in 205 days
#3 posted 03-10-2018 07:34 AM
- LesB
I agree, 3/8” dowels sound perfect.
-- ~Jim
View Woodknack's profile
Woodknack
12341 posts in 2501 days
#4 posted 03-10-2018 07:37 AM
View rwe2156's profile
rwe2156
3073 posts in 1602 days
#5 posted 03-10-2018 02:07 PM
5/16 min 3/8 better.
  1. depends on width I would go one every 6-8”.
BaltimoreChris
4 posts in 241 days
#6 posted 03-10-2018 04:00 PM
Thanks. I was worried that 3/8 might be too much since the tenon barely stuck out more than an inch. So I went with 5/16. I have 5 tenons across the width of the table, which is about 42 inches wide. I used one dowel per tenon and glued the entire middle tenon area. Fingers crossed, will need some sanding when done.
View JADobson's profile
JADobson
1167 posts in 2232 days
#7 posted 03-10-2018 04:04 PM
I used 1/4” on my farmhouse table. They’ve been just fine. I have 4 across a 40” wide top.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
BaltimoreChris
4 posts in 241 days
#8 posted 03-10-2018 04:05 PM
Related to breadboard ends, do I need to do anything special when I apply poly to the table top. I plan to spray a general finishes topcoat (several layers) after I stain the pine top. Does the movement of the main table compared to the breadboard ends cause any issues with the poly topcoat?
View splintergroup's profile
splintergroup
2253 posts in 1343 days
#9 posted 03-11-2018 02:29 PM
As to the dowel size, 1/4” will give you the required strength so go with what looks good. I think 3/8 is ballpark for typical mortice pins in furniture but smaller will avoid compromising the tenon structure.
The poly will be fine. If you have a thick coat, scoring the joint with a razor blade will keep any crack from flaking off from the table, but even that is unlikely.
