Delta Rockwell Drill Press Question - What is it?
Forum topic by PittsburghTim posted 03-09-2018 11:13 PM 242 views 0 times favorited 7 replies Add to Favorites Watch
View PittsburghTim's profile
230 posts in 2251 days
03-09-2018 11:13 PM
Topic tags/keywords: drill table press
I picked up a vintage (40s or 50s) Delta DP220 Drill press that has two tables. The top one is a regular table and the bottom one has a plywood top (looks factory-made) with what appears to be a pipe flange-like cast iron piece mounted to it, directly over what would be the center hole of the table. It’s a cast piece painted the original Delta grey, but I cannot figure what it was for. Was it a support for some accessory? I would love to know what it is, but have not come up with anything after hours of scouring the internet.
-- She asked me, "Who are you going to please with that?" I said, "Me."
7 replies so far
#1 posted 03-09-2018 11:25 PM
Here is a picture of it.
View bndawgs's profile
244 posts in 511 days
#2 posted 03-09-2018 11:34 PM
Have you checked over at owwm?
Wonder if it was to turn it into some sort of spindle sander?
6467 posts in 2128 days
#3 posted 03-09-2018 11:35 PM
It’s just some homemade gizmo from a previous owner – there is no telling what it’s for and only they would be able to tell you what they made it for. BTW: If you have the serial number of the press, you can figure out when it was made and then look at the catalog for that year to see all the options available.
View Richard Lee's profile
Richard Lee
104 posts in 704 days
#4 posted 03-10-2018 01:01 AM
User added,as others have said.
View BoardButcherer's profile
134 posts in 23 days
#5 posted 03-10-2018 02:34 PM
Looks like a guide bushing. Only use I can fathom is that this drill was set up for the specific purpose of putting a hole in a very awkward piece of material that required a long drill bit to reach, and that that bushing was used to keep the bit from flexing in the middle.
I’ve seen people try similar stuff for drilling small holes in the end of large round stock. It never worked well.
View MrRon's profile
4665 posts in 3172 days
#6 posted 03-10-2018 07:07 PM
Delta DP’s with the round base were produced between 1932 and 1937. I have the same DP (floor model). It is a great DP. I’ve owned it for the past 35 years and it is still going strong. The bearings on the original motor quit, so I replaced it with a motor I had lying around. It is probably the most used tool in my shop. In 1934, that DP cost $32.85. By your description of “two” tables, the previous owner may have put an additional table on it. Normally, they only have one table.
#7 posted 03-11-2018 08:03 PM
I can see the top piece is bolted to the table. Looks like it may have been a “lathe” setup.
