Sawstop Dado cartridge
Forum topic by agallant posted 04-25-2011 07:54 PM 1140 views 0 times favorited 3 replies Add to Favorites Watch
View agallant's profile
agallant
551 posts in 2884 days
04-25-2011 07:54 PM
Do you have to put in the dado cartridge if you use a dado blade? Has anyone tried to run the saw with the normal cartridge in while using a dado blade?
3 replies so far
View JJohnston's profile
JJohnston
1622 posts in 3289 days
#1 posted 04-25-2011 09:14 PM
Yes. The saw recognizes that you’ve got the dado set (8”) and the regular brake (for 10” blade) installed, and won’t run. There’s a small range of correct distance between blade and brake, and with this setup, the brake is over an inch away.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View mcase's profile
mcase
446 posts in 3126 days
#2 posted 04-26-2011 03:55 AM
Yes
View lanwater's profile
lanwater
3111 posts in 2931 days
#3 posted 04-26-2011 08:00 AM
Yes you do.
-- Abbas, Castro Valley, CA
