Tube bending die out of wood
Forum topic by Tbirkey posted 03-08-2018 07:35 PM 448 views 0 times favorited 6 replies Add to Favorites Watch
View Tbirkey's profile
Tbirkey
3 posts in 278 days
03-08-2018 07:35 PM
Hey yeall this is my first time on the Forum. What I am trying to do is make an 8in CLR die to bend 1 inch tubing. The people who make my Bender want to charge a ridiculous amount to make it out of metal but that’s not necessary. So my plan is to get 2 3/4 inch Oak boards and use the jigsaw to cut out the radius and then use a half inch Cove bit on a router then Bolt them together. so my mom is mailing me her old Ryobi router with 1/4 inch collet and use a half inch Cove bit maybe from eBay in it. I’ve been doing a little reading on routers and my big question is is it okay to use that big of a Cove bit on a 1/4 inch Shank or will it be too chattery especially on hardwood. I’ve seen these dies before and been on other forms and it works out really well with people but they don’t share a lot of the details and I’m a woodworking retard so if anybody could please chime in and maybe give me a suggestion or anybody’s experience on how to do this the best way possible or anything else I’m not considering.
View John Smith's profile
John Smith
1481 posts in 360 days
#1 posted 03-08-2018 07:41 PM
to prevent over-bite, chipping, chattering, splinters, smoke and fire
is to not be too aggressive in the cuts. several passes taking small bites
will render the most favorable (and safe) results.
taking too much material off at high speed could snap a 1/4” shank
very quickly and the head goes flying off into who knows where (or who).
work smart – work safe.
-- I started out with nothing in life ~ and still have most of it left.
View Bill_Steele's profile
Bill_Steele
450 posts in 1929 days
#2 posted 03-08-2018 09:43 PM
+1 what John said. Take several passes using a small bite (1/8” or less) with each pass rather than hogging off too much stock at one time. If you had a 1/2” shank bit you might be able to take a larger bite.
Tbirkey
3 posts in 278 days
#3 posted 03-08-2018 10:35 PM
Thank you very much.!!
View Warren's profile
Warren
15 posts in 585 days
#4 posted 03-08-2018 11:17 PM
What king of tubing to you want to bend with this jig?
Tbirkey
3 posts in 278 days
#5 posted 03-09-2018 12:14 AM
1” .156 wall 1020
View shipwright's profile
shipwright
8163 posts in 2996 days
#6 posted 03-09-2018 05:15 AM
I wrote this hours ago but apparently didn’t post it.
If you are planning to cut a half round in a concave and a convex surface and then squeeze the two together over the tubing, you will need a couple of jigs for the router.
Here is one that I made for a similar operation on a concave surface.
http://lumberjocks.com/projects/74529
Something like this would likely get your concave surface done. Although technically possible without a jig, I think a convex jig would be a very good idea as well. Flat router bases just don’t lend themselves well to this kind of thing.
Of course I agree with the suggestions above about many light cuts, particularly as the bit will need to be extended farther than normal from the collet.
Or maybe I don’t understand your intention?
