resin and polyurethane
« back to LumberJocks.com Site Feedback forum
Forum topic by drwoj posted 04-24-2011 04:27 PM 1796 views 0 times favorited 4 replies Add to Favorites Watch
View drwoj's profile
drwoj
14 posts in 2887 days
04-24-2011 04:27 PM
hi everyone i have a question i hope u can help
i have a 5 foot chalupa slab that i am working on i had put teak oil to pop the grain then i put polyurethane on that at least 3 coats i want to go thicker so the question is can i use resin to put over the polyurethane to make it thicker?
thanks so much
-- drwoj
View cabs4less's profile
cabs4less
235 posts in 3002 days
#1 posted 04-24-2011 06:42 PM
when you say resin you mean that epoxy bar top finish ?
-- As Best I Can
drwoj
#2 posted 04-25-2011 01:39 AM
yes it is a pourable resin it is used for bar finishes
-- drwoj
cabs4less
#3 posted 04-25-2011 01:58 AM
my ONLY CONCERN WOULD BE THE ADHESION POLY SITS ON TOP A SURFACE AND IN THEORY YOU COULD PEEL IT OFF LIKE A SHEET BUT I NEVER SEEN THIS I WOULD SAY AS LONG AS YOUR AS YOUR POLY IS CURED FOR A WEEK OR TWO GO FOR IT BUT I WOULD CURE IT JUST IN CASE THE SOLVENTS IN THE EXPOXY ARE STRONGER THAN MINERAL SPIRITS
-- As Best I Can
View SASmith               's profile
SASmith
1850 posts in 3227 days
#4 posted 04-25-2011 02:17 AM
I have never done it, but the epoxy I used in this bar can be used over poly:
http://lumberjocks.com/projects/45436
A few comments down in the post I give a link to the instructions.
Check out the directions and see if it fits your needs.
Scott
-- Scott Smith, Southern Illinois
