Drawer Lock Bit
Forum topic by cajunworkshop posted 03-08-2018 03:07 PM 307 views 0 times favorited 2 replies Add to Favorites Watch
View cajunworkshop's profile
cajunworkshop
64 posts in 1200 days
03-08-2018 03:07 PM
Received my Frued 99-240 Draw Lock Bit. Been mostly using pocket hole joinery on thedrawers I have been building Going to take this out to my shop and play around with it in the next couple of days( 29 degrees here this morning just a big buddy heater in my shop).
Before I get started anyone suggest a starting point on height of the bit and how much it protrude from my router table fence opening? I will be using plywood all 4 sides 1/2” or some times 3/4”
Any comments on your success or failure using a drawer lock bit?
Thanks
-- Cajun Workshop Greenville, SC
2 replies so far
View rwe2156's profile
rwe2156
3174 posts in 1685 days
#1 posted 03-08-2018 04:39 PM
About 1/2 way thru front as pictured. Trial and error but once you get it figured out, cut your sides a bit wider to you can trim off the blow out or use a backer board.
I don’t use mine anymore with plywood the tear out is an issue I don’t want to deal with.
I’ve found scribing a line cross grain prior to cut will just about eliminate it.
Keep a set up block for reference.
View AlaskaGuy's profile
AlaskaGuy
4818 posts in 2514 days
#2 posted 03-08-2018 04:42 PM
