Bandsaw Blade question???
Forum topic by Harold posted 249 days ago 210 views 1 time favorited 8 replies Add to Favorites
View Harold's profile
Harold
294 posts in 374 days
249 days ago
Topic tags/keywords: bandsaw milling veneering question
A friend will ordering a carbide tipped bandsaw blade for the 18” Delta. What my question is, what type of tooth arrangement would work best. He will be resawing and roughing out bowl blanks, the wood used will range from Mango( similar to a hard maple) on the soft side up to Keawe ( mesquite) and Ohia
(similar to walnut)on the harder end. We are leaning towards a 3/4” wide blade, but I am trying to get alittle more info on the tooth setup that will work best. The carbide blade is alittle pricey, but the conventional blades just don’t last. Also I seem to get alot of resin buildup on my tools, is there a product that works well for this, keep in mind I live in a very humid/salty location so something that would protect the tools while not contaminating the wood would be ideal.
thanks.
-- If knowledge is not shared, it is forgotten.
View Tony's profile
Tony
620 posts in 557 days
249 days ago
Lenox Blades http://lumberjocks.com/reviews/75 , http://www.lenoxtools.com/enUS/Product/Tri-master.html
I would definitely recommended this blade. 3/4” 3tpi. Standard.
I have been re-sawing 12” wide Oak board up to 10’ long ALL day,with no problems at all. The 3/4” is not too good for tight curves, but just knocking the corners off bowl blanks no-problems.
A little expensive, but for me it was worth it.
Harold
249 days ago
thank you Tony, I was curious if the skip tooth would run alittle cooler and perhaps mitigate the resin problem.
View Blake's profile
Blake
2206 posts in 401 days
249 days ago
Where do you buy these? I followed the link but it seems to be information only.
-- Check out my new website! http://www.theeasellife.com
View Sawdust2's profile
Sawdust2
868 posts in 614 days
249 days ago
Check www.highlandwoodworking.com for it’s resawing blade. It is highly recommended.
View John Ormsby's profile
John Ormsby
183 posts in 263 days
248 days ago
Give Louis Iturra a call at 1-888-722-7078 I believe he sells Lenox blades. He is very knowledgeable. You can also purchase a blade tension gage if you wish. I adjust my expensive band saw blades with a tension gage and have never broken a blade. I use a Lenox 1” on my MM24 exclusively. I don’t think you will have any problem with a 3/4” on your 18” wheels. You will be amazed at the quality and speed of cuts. I have sawn green and dry and soft and exotic hardwoods (such as 2”x7” pink Ivory & 4”x5” Macassar Ebony) with no problems. I would suggest you take the band off once in a while and give it a good cleaning. This will improve the cut and give you a longer life on an expensive blade. Don’t be afraid to set the tension at the factory recommendation. It will give you the best performance. I set the 1” at 28,000 psi.
Here is a link to Lenox for more info on the Tri-master blades. The vari-tooth design will give you the smoothest cut if that is what you are looking for. It looks like they do not make the vari-tooth in a 1/2” or 3/4” band. Hope this helps, John
-- Oldworld, Fair Oaks, Ca
View Doug S.'s profile
Doug S.
210 posts in 235 days
234 days ago
I’ve got a 1” Lenox Tri-Master on a MM16 BS and it will slice up Mango very happily and leave a very nice surface that doesn’t need much (if any) cleanup – maybe 1 light pass thru a drum sander afterwards. If you can keep the feed rate pretty consistent I very often get no blade marks at all. I’d have to double check mine but I think it’s the 2/3 TPI but I think they also have a 3/4 in that width. Even Ipe cuts like butter with it. i know they also came out with a slightly less costly blade than the Trimaster that I haven’t tried but read good reviews from folks that have used both. I used to use a Woodslicer blade on my previous Jet 14” and would probably have bought 5-6 blades at around $175 so it puts the TM cost into a bit of perpective. Mine shows no signs of needing a replacement for a long time to come.
-- Use the fence Luke
6517 posts in 378 days
233 days ago
I agree with Tony. a 3/4 blade with 3TPI will nock the socks off the thinner blades with lots of teeth.
Harold
233 days ago
We got the tri-master blade, I don’t have an educated opinion yet but I am impressed thus far. If it will last like the carbide tipped circular blades on the hard woods it will save a great deal of money as well as time and headaches.
Bookmark And Share This Page
