Vega Fence with a router table extension?
Forum topic by StoutSawdust posted 03-06-2018 04:58 PM 278 views 0 times favorited 4 replies Add to Favorites Watch
View StoutSawdust's profile
StoutSawdust
12 posts in 151 days
03-06-2018 04:58 PM
Topic tags/keywords: vega fence router table extension
Hey guys, can any vega fence owners tell me if the fence rails can support a router table extension or is that too heavy for it without support arms?
Thanks
-- Success is the result of perfection, hard work, learning from failure, loyalty, and persistence.
View Kaleb the Swede's profile
Kaleb the Swede
1835 posts in 1995 days
#1 posted 03-06-2018 05:51 PM
I have a vega that I made a cabinet for that has the router table on the left side of the saw. But I have the cast iron extension.
I’m sure if you were going to do it on the right side then you can support it with wood going to the floor.
-- Just trying to build something beautiful
StoutSawdust
#2 posted 03-06-2018 06:31 PM
Thanks for the reply, I was hoping to do a suspended one. Wanted to check before I bought one. Ordered a delta fence but man they can’t package their items safely for crap. The fence is all dinged up.
View dschlic1's profile
dschlic1
433 posts in 1995 days
#3 posted 03-07-2018 06:13 PM
I have a Vega. I also have a router table mounted to the left of the saw. However I support the table with struts down to the base of the saw. The front rail on the Vega is a round pipe. I think that it would support a table, however the back rail is a thin wall square tube, which probably would not.
View GrantA's profile
GrantA
163 posts in 1433 days
#4 posted 03-07-2018 06:42 PM
I don’t see why not depending on the size & weight. If you’re talking about a 27×43 wing with a 3hp router then I’d say you need legs. If a 27×20 or so and a “normal” router it should be fine.
I have a Delta T2 right now with a 27×18x1.5 MDF table, incra plate and ridgid router with no legs.
I just got a Unisaw and it has a Vega pro fence, I’m planning to build a new router table wing and outfeed combo so I’m going to want (probably need) to add “legs” but I’m hoping to keep the footprint the same. The legs will be angled to the saw’s base. Will see how it turns out!
