rough jointer outfeed bed
Forum topic by UMP55 posted 03-06-2018 04:29 PM 480 views 0 times favorited 7 replies Add to Favorites Watch
View UMP55's profile
UMP55
7 posts in 285 days
03-06-2018 04:29 PM
I recently bought a small bench jointer. The infeed bed is machined to an almost mirror finish. The outfeed bed is machined, but a lot more rough. Im getting a very small mark on my boards when using. wondering if there might be a small imperfection on the outfeed table that is “scratching” my board. I checked the knives and they are fine. Wondering if anyone has honed their jointer beds. I was going to get a small (6”x3”x1”) wet stone. I have a lot of experience in stoning large machined surfaces, so I know it wont hurt. Any input would be greatly appreciated.
-- “Wherever you go, there you are.”
7 replies so far
View bilyo's profile
bilyo
424 posts in 1306 days
#1 posted 03-06-2018 04:53 PM
I would just try wrapping a piece of 180 grit wet/dry sandpaper around a flat block and sand the outfeed table like a piece of wood. You will do no harm and you will probably take down any burr or ding that is causing trouble. Then, wipe it clean and put on a coat of paste wax.
If you can feel the offending spot with your hand or finger, you may be able to fix it with just a flat fine cut file.
View BoardButcherer's profile
BoardButcherer
144 posts in 298 days
#2 posted 03-06-2018 05:24 PM
Hone it with the stone. You’ll use the stone regularly if you buy a set of chisels and/or hand planes anyways, and stone honing produces a more consistent finish as I’m sure you know.
View TheFridge's profile
TheFridge
10756 posts in 1690 days
#3 posted 03-08-2018 05:58 AM
Do it once and be done.
View tomsteve's profile
tomsteve
879 posts in 1423 days
#4 posted 03-08-2018 03:34 PM
i honed the tables of a benchtop planer i had with no problems
View fivecodys's profile
fivecodys
1228 posts in 1840 days
#5 posted 03-08-2018 04:50 PM
Hone it with the stone. You ll use the stone regularly if you buy a set of chisels and/or hand planes anyways, and stone honing produces a more consistent finish as I m sure you know.
- BoardButcherer
X2
-- I always knew I would grow old, But I expected it to take longer!
View Stumble's profile
Stumble
7 posts in 280 days
#6 posted 03-11-2018 07:46 PM
Take the top off and mount it to a table somewhere. Then go after it with a wet stone and plenty of oil, it may take a little while but it is worth it. Then protect that finish with paste wax, or a wipe on teflon wax.
UMP55
7 posts in 285 days
#7 posted 03-11-2018 08:39 PM
Thanks for all the feedback. I decided to return the bench jointer and ordered the Ridgid JP0610. I realized I settled on the bench model and wouldn’t really be happy with it.
