Need help with bandsaw tensioner/spring
Forum topic by kanihoncho posted 757 days ago 514 views 0 times favorited 2 replies Add to Favorites Watch
View kanihoncho's profile
kanihoncho
56 posts in 1239 days
757 days ago
I am in the middle of changing blades on my Jet JWBS-14CS 14” bandsaw. The silver tensioner block all of a sudden will stop even though I am still turning the tension knob so the blade never tightens. Not even close, there’s still a 1/4 inch gap.
I’m assuming the spring is shot? If that is the case does anyone have a recommendation for a superior spring?
Thanks.
2 replies so far
View Mickey Cassiba's profile
Mickey Cassiba
315 posts in 1197 days
#1 posted 757 days ago
I’ve got a Carter Cobra on my Delta 14. You couldn’t hurt that thing if you ran over it . I would first check my blade length though…I’ve seen over(and)undersized bands. I’d also have a look at the threads on your tensioning rod for a stripped area. Either condition would produce the problem you describe
-- One of these hammers oughta fix that...
View cabmaker's profile
cabmaker
1022 posts in 975 days
#2 posted 757 days ago
I had a cheapo 14 incher thirty years or so ago that I experianced a similar problem with. I found finally that the block was binding in the ways. I took it all apart, filed the ways and cleaned up the block then life was good (till the motor fried) BTW I was not suggesting that your saw is a cheapo but mine was for sure. It was an early china special and in that era they were really bad.
