What to stain or coat my burnt Cypress coffee table with.
Forum topic by MBozeman87 posted 03-06-2018 12:11 AM 1206 views 0 times favorited 15 replies Add to Favorites Watch
View MBozeman87's profile
MBozeman87
5 posts in 105 days
03-06-2018 12:11 AM
Topic tags/keywords: wood work coffee table cypress wood wood staining coating finished product
I need help with finishing a coffee table that I have made out of Cypress. I used a torch to burn the wood and then sanded in down so it wouldn’t be so dark. I need all the suggestions and information I can get on what to stain or coat it with. I don’t want to go to dark and would like to keep it as natural looking color as possible. Thank you in advance.
15 replies so far
View Ron Aylor's profile
Ron Aylor
2634 posts in 670 days
#1 posted 03-06-2018 12:24 AM
Keep it simple and perhaps finish with blonde shellac.
-- Ron in Lilburn, Georgia.  https://ronaylor.wordpress.com
View John Smith's profile
John Smith
992 posts in 186 days
#2 posted 03-06-2018 12:25 AM
burnt cypress ? can you post some photos ? sounds interesting.
but, for your question: “would like to keep it as natural looking color as possible. “
[natural cypress is not burned].
-- Graduated Valedictorian from the University of HardKnocks --
MBozeman87
5 posts in 105 days
#3 posted 03-06-2018 01:10 AM
John Smith what I meant was the wood that isn’t burnt I would like to keep similiar to the color it already is. Don’t want the put something on it that will make it a lot darker is all I meant. Keep in mind that in these pictures the table isn’t completely yet so don’t be to harsh with your comments. Thinking about adding a bottom rack to put stuff or just to prop feet on. What y’all think? This is only my second wood project on my own so I’m proud of it.
MBozeman87
5 posts in 105 days
#4 posted 03-06-2018 01:14 AM
What would y’all suggest since I’ve put pictures up on what to put on it? Really just want protection or should I stain it too?
John Smith
#5 posted 03-06-2018 02:09 AM
very cool !! it has a nice patina to it. you should be proud to show it off.
View CaptainSkully's profile
CaptainSkully
1600 posts in 3581 days
#6 posted 03-06-2018 02:12 AM
Polycrylic comes in a satin finish that would encapsulate, protect and the satin finish I think is more appropriate for the theme of the table than anything glossy. It’s also water-based so application and cleanup is easy.
-- You can't control the wind, but you can trim your sails
MBozeman87
5 posts in 105 days
#7 posted 03-06-2018 02:53 AM
Thank you all for the advice!!
117115 posts in 3600 days
#8 posted 03-06-2018 03:57 AM
Is this going to be used indoors or outside?
MBozeman87
5 posts in 105 days
#9 posted 03-06-2018 04:28 AM
Inside
#10 posted 03-06-2018 04:41 AM
Then Polycrylic should do a good job,it takes a minimum of two coats.
View Aj2's profile
Aj2
1423 posts in 1821 days
#11 posted 03-06-2018 04:41 AM
That’s a very western looking tavern / steak house table. So it should be coated with whiskey, beer and bread crumbs from garlic bread. I would think steak juice and barbecue sauce is ok too.
-- Aj
View OSU55's profile
OSU55
1696 posts in 2012 days
#12 posted 03-06-2018 01:22 PM
I would suggest plain oil based polyurethane applied like an oil finish. I use use Minwax, satin in this case. Thin it 1 to 1 with mineral spirits, flood it on, keep it wet for 10-15 minutes, wipe it off. Repeat at least 3 times. You could do a last coat as wipe on, leaving a thin film. Test on the bottom or a piece of scrap.
View CharlesNeil's profile (online now)
CharlesNeil
2410 posts in 3893 days
#13 posted 03-06-2018 01:37 PM
I agree with Jim, a water base finish is the only thing that will not alter the color, initially it will look browner, just because its wet, but when it dries it will dry clear.
Any solvent, or oil will react with the tannins in the wood and with cypress it usually goes brown with a amber tint to it as I recall .
OSU55
#14 posted 03-07-2018 12:43 AM
Agree wb is best if you dont want any color, but it will look very lifeless, no chatoyance. OB poly will make add some very light tone, and make it look wet, as well as add chatoyance depending on the sheen. Wetting with ms is close. Whatever you use, seal up the bottom well.
View AxkMan's profile
AxkMan
65 posts in 149 days
#15 posted 03-07-2018 01:27 AM
If you want to stain, you can use a lighter tone of the stains. They don’t stain very well but bring it to a lighter color.
