Can wood from limbs be used for bandsaw boxes?
Forum topic by jmaybe posted 04-23-2011 12:00 AM 2621 views 0 times favorited 7 replies Add to Favorites Watch
View jmaybe's profile
jmaybe
2 posts in 2886 days
04-23-2011 12:00 AM
Topic tags/keywords: question bandsaw box
I just got done cutting up a 100 year old hickory that was partially felled in a recent storm. I’m going to have a large portion of the trunk cut up at the mill, but was wondering about the limb pieces.
I have a lot of wood from the limbs cut up that I’d love to use for bandsaw boxes. However, I think I understand that wood from limbs is undesirable in most applications because it is unstable.
Is that so and in what way?
If it is undesirable for furniture etc does it make it unusable for small projects?
Thank you in advance.
-John
7 replies so far
View Gregn's profile
Gregn
1642 posts in 3102 days
#1 posted 04-23-2011 12:20 AM
I would think that used as band saw boxes would be ok. Its when you try to make straight boards that they will twist on you.
View David Grimes's profile
David Grimes
2078 posts in 2758 days
#2 posted 04-23-2011 07:57 AM
May I ask what a band saw box is ? I truly have no idea. Thanks.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View Pawky's profile
Pawky
278 posts in 2922 days
#3 posted 04-23-2011 09:08 AM
Hey David. Here are a few links to some bandsaw boxes people have made here:
http://lumberjocks.com/projects/680
http://lumberjocks.com/projects/37880
http://lumberjocks.com/projects/17868
I hope that helps
View Scsmith42's profile
Scsmith42
125 posts in 2795 days
#4 posted 04-24-2011 12:06 AM
John, the cellular structure of limb wood is inconsistent, due to the fact that the upper side of the limb is in tension and the lower part is in compression. When milled, the wood tends to move quite a bit, and every time that you joint/plane/sand it down further, it continues to move.
Expansion/contraction of the wood due to humidity changes is also not consistent, which is why it is usually not used for woodworking projects.
-- Scott, North Carolina, www.quartersawnoak.com
View Nomad62's profile
Nomad62
726 posts in 3076 days
#5 posted 04-27-2011 10:11 PM
It’s not unuseable, just more difficult to rely on. A lot of turners use limb wood because it’s cheap/free, and it works well most of the time. If your project is small, such as a bandsaw box, I would think it okay so long as you don’t bet the bank on it. Have some fun and see what you get!
View Bertha's profile
Bertha
13550 posts in 2811 days
#6 posted 04-27-2011 10:16 PM
I’m with these guys! Free wood, get in there and play with it. If it cups and twists on you, take the drawer out and use it as a change cup!
View racerglen's profile
racerglen
3112 posts in 2899 days
#7 posted 04-28-2011 02:19 PM
I’ve done a few bandsaw cups from limbs, mostly Cherry, never tried to lid them
or make a drawer in them. They worked pretty well, no warpage or other issues, BUT the wood was VERY dry when I got
to it. Other limbs such as a neighbours Plum have mostly ended up as butter knives, jam spreaders and such, the stuff’s a bear to dry without cracks.
-- Glen, B.C. Canada
