Wood putty inlay dilema
Forum topic by exteach posted 03-05-2018 02:55 PM 331 views 0 times favorited 4 replies Add to Favorites Watch
View exteach's profile
exteach
1 post in 677 days
03-05-2018 02:55 PM
Topic tags/keywords: question alder
I have been inlaying contrasting wood putty in alder. The putty that extends beyond the inlay leaves a cloudy stain where it was prior to sanding. More sanding does not eliminate the stain. I have used sanding sealer and the stain still appears. It is frustrating when I get a great inlay and then when I fill and sand it the result is less than satisfactory. The surface of the inlay is great but the surrounding area has that darn cloudy stain. Is there a technique that I could use to eliminate the stain?
-- Neil, Oregon
View WyattCo's profile
WyattCo
86 posts in 132 days
#1 posted 03-05-2018 03:31 PM
You have filled the grain and pores on the wood surface where the putty was. You’ll have to sand or plane it down to the non-sealed depth.
View BoardButcherer's profile
BoardButcherer
144 posts in 122 days
#2 posted 03-05-2018 07:45 PM
Try putting a very light coat of the sealant you’re going to use on the wood before you fill it with putty to keep it out of the pores and grain. When you go to sand the putty a couple light passes should take the excess off without staining the wood before you get through the sealant.
View patcollins's profile
patcollins
1685 posts in 2892 days
#3 posted 03-06-2018 01:48 AM
put masking tape around the spot you are putting the putty, keeps it out of the grain and keeps it from staining the wood.
View Jim Finn's profile
Jim Finn
2658 posts in 2949 days
#4 posted 03-06-2018 03:47 AM
Yes I agree try putting a coat of shellac on the wood first. When I make my own filler for small flaws in wood, I mix
sanding dust with shellac and apply that and when it dries I sand it off and then apply shellac over the entire surface, sand lightly and then apply poly finish.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
