Wooden plane's mouth - out of angle
« back to Hand Tools forum
Forum topic by Tomicsek posted 03-05-2018 02:53 PM 320 views 0 times favorited 3 replies Add to Favorites Watch
View Tomicsek's profile
Tomicsek
1 post in 197 days
03-05-2018 02:53 PM
Topic tags/keywords: plane question
Hello people,
I am repairing wooden hand plane with a chip breaker, I want it to be a smoother. At the end of this day I started to feel a bit proud of myself, cause I repaired the chip breaker, made a new handle, a new wedge (both out of black locust which is native to North America but for a few hundred years it has been really widespread here in Middle-Eastern Europe, so it’s everywhere), scrubbed the old smelly and thicky finish, straightened the sole, repaired the throat etc… So I felt I’m done when I started to think about a wooden patch at the mouth to close the opening a little bit… Then I saw it. The mouth is just out of angle… I drew lines accross the sole and measured the difference between the two corners of the blade… One of the corners is about 2 mms out of line wich is perpendicular to the wood grain…
My question is: Should I make the opening straight and perpendicuar to the body, does it worth it, or make the new mouth tightening patch ‘slanting’ as well and shouldn’t be bothered by the angle?
Thanks for your answers!
Tom
3 replies so far
View HammerSmith's profile
HammerSmith
137 posts in 198 days
#1 posted 03-06-2018 04:30 AM
~make the opening straight and perpendicuar to the body..
I’m not sure if I understand your description of the problem, but it sounds like the blade support isn’t right.. might have to file one side down a little.. It’s hard to describe, but I had to do this on a block plane once. Otherwise the blade would’ve had to be ground out-of-square to make a proper cut.
Can you post a picture of it?
-- ~Jim
View Don W's profile
Don W
18930 posts in 2682 days
#2 posted 03-06-2018 12:03 PM
Does the blade follow the mouth? Are you saying the back of the mouth and the bed is out of square?
I agree pictures would help
View Tim's profile
Tim
3812 posts in 2075 days
#3 posted 03-06-2018 01:39 PM
A skewed plane has a bed like that, but by more than 2 mm if it was on purpose. The bed being flat and the wedge seating properly is the really important thing. Check the bed for perfect flatness and the wedge fit and you should be good.
