steel city cabinet saw
Forum topic by rick1950 posted 03-05-2018 02:53 PM 595 views 0 times favorited 7 replies Add to Favorites Watch
View rick1950's profile
rick1950
3 posts in 111 days
03-05-2018 02:53 PM
I just bought a steel city 35951c 10” cabinet saw . their is a few parts missing and i’m not having any luck finding them first there is no blade guard anybody know what will if any fit and i’m not real familiar with the leveling of the 3 piece table it appears first level with center piece then set miter slots any and all information about this saw whould really be apprieciated,
thanks Rick
7 replies so far
View Mike_D_S's profile
Mike_D_S
478 posts in 2242 days
#1 posted 03-06-2018 10:54 AM
Rick,
First off, if you don’t have the manual, here’s a link to it:
http://steelcitytoolworks.com/media/product-manuals/35951.pdf
I’ve got a Steel City 35605 10” 3HP saw. I like it pretty well. The one time I needed parts, I was able to order them from the Steel City Canada guys. They have a small stock of parts from the US importer’s operations, so give them a call or submit a parts request on line and see what they say. You can use the manual to get the part numbers.
My Steel City saw was also sold under Craftsman label as well. The blade guards may be interchangeable so you can do some looking around. A few of the parts are available on the standard spare parts web sites for the Craftsman version.
Leveling the sides is just a trial and error process. Loosen the bolts holding the extensions to the rails and then loose the bolts from the extension to the main table a little. Then just rubber mallet it (or hammer and block of wood) until you’re happy, then tighten. You want it level, but I wouldn’t get too obsessive about it.
Once you get everything level, then loosen the table mounting bolts to the cabinet following the instructions in the manual until you’re happy. Takes a bit of trial and error, but not difficult. You don’t absolutely need it, but a good dial gauge mounting on a runner in the miter slot helps out here if you’re sort of picky.
Mike
-- No honey, that's not new, I've had that forever......
rick1950
3 posts in 111 days
#2 posted 03-07-2018 02:34 AM
thanks I did as you suggested and it leveled out almost dead flat, thanks . I also printed the manual from your link the only problem is page 35 is not there. In the table of contents page 35 is the parts page. I’m almost there but I would like the parts list and I assume that is where the Canadian contact info is because I couldn’t find it in the manual thank you again and if you or anyone else has the parts page I would appreciate having it. The system to level the 3 part table with the treaded bushings work well al long as you take your time and sneak up on it
Rick
Mike_D_S
#3 posted 03-07-2018 07:20 AM
You can also check out the Craftsman 22116 as a potential match for the Steel City 3595x line. The pics are a little different, but the other specs seems sort of close.
https://www.searspartsdirect.com/model-number/351221160/0247/0744600.html
Contact info for the canadian dealer:
https://www.steelcitymachines.ca/
My understanding is this is a division of the General Int’l group based in Canada. When I talked to them, they told me they have a stock of parts for older machines they got in the purchase when Steel City US closed. I was able to get a elevation worm gear for my trunnion but not the whole assembly. Common items like safety guards might be easier since they tend to be common among different machines.
Mike
rick1950
3 posts in 111 days
#4 posted 03-08-2018 04:59 AM
Thanks Mike
I called Canada and now have a blade guard and anti kickback fingers coming only place i could find them . Checked out the Craftsman but the mounting was different. People were very helpful and friendly
Thanks again
Rick
Mike_D_S
#5 posted 03-08-2018 08:40 AM
Rick,
Glad I could help. I like my SC saw. I’m not holding it up as the perfect table saw, but it serves my purposes and I’ve made some nice stuff on it.
Mike
View Ebrabender's profile
Ebrabender
3 posts in 109 days
#6 posted 04-18-2018 01:34 PM
Rick How you liking the saw so far? I am picking one up tomorrow that I found on CL. Couple of things I noticed is the fence doesn’t “glide” as nice as I would prefer and didn’t dig into it too far yet. How does your fence slide? I am wondering if there are some plastic pieces under there that are wore out and need replacing.
Ebrabender
3 posts in 109 days
#7 posted 04-18-2018 01:46 PM
Thanks Mike
Thanks again
Rick
- rick1950
Mind me asking what they charged? These are two items missing from my saw as well just not sure I would use them though to be honest.
