| Forum topic by BANick | posted 622 days ago | 693 views | 1 time favorited | 31 replies | ![]() |
622 days ago |
Topic tags/keywords: question plywood I don’t have the luxury of owning a pick-up truck, I just have the old SUV that carries the family around. So to get plywood and other sheet goods home is somewhat of a pain since I have to get it cut where I buy it to fit in the back of the SUV. It works ok most of the time since I usually plan my cutlist before I buy the material but I am getting into projects where I want to bring home the sheets in one piece and cut them myself. -- Nick, Fremont, CA. |
622 days ago |
No pickup truck for me either, and I don’t have an SUV. I have a small wagon. I can take about 4-6 pieces of 4×8 sheets of plywood home safely on the roof rack w/ rails. I use ratcheting straps to tie the pieces down. I drive pretty slowly—the winds can be pretty hazardous. I see you’re in Freemont—once I bought a bunch of BB from Macbeath in Berkeley then drove over the San Mateo Bridge on a windy day…boy was that crazy. I think next time I might try to separate sheets with some kind of spacer to allow the wind to pass through. Also, in my car, the front passenger seat folds down flat. I can fit 9’ boards in and still close the hatch. This weekend I brought home 2 4×8 sheets of pegboard, 3 pieces of 4×8 birch ply, a few small sheets of MDF and 20 2×4s. Still had plenty of room inside the car. It works, though. I have a BORG about 4 miles from where I live (don’t we all). Hopefully once I get my shop cabinets built out, I won’t be buying too many sheet goods. I have contemplated getting a battery powered circular saw though and cutting down sheet goods in the lot. Makes a lot more sense and makes it easier to get in and out of the shop too. |
622 days ago |
I have a freind that works close to my source for plywood. I call him and pick it up. The other option is to have deliverd by the company that sells it. |
622 days ago |
If you have a rack on top, you could tie it to that. I have a small pickup and have the same problem with 5’x5’ sheets of baltic birch plywood. -- Gary, East TX -- The longest journey begins with a single step. |
622 days ago |
You guys ever consider a utility trailer? -- A mind, like a home, is furnished by its owner |
622 days ago |
Nick, I have a Jeep Cherokee with Yakima racks on it. They are rated at 120 lbs. each, so it’s good for a couple of sheets of plywood, or about 50 bft of lumber. I usually make a large haul when I go to the lumber yard, because it’s over 200 miles round trip, and for that I have a 5’ x 8’ trailer that I pull. -- Tim -- http://tmuli.com |
622 days ago |
I have a 5’ x 8’ utility trailer. Works well. Can be pulled by most vehicles. -- DaveH - Boise, Idaho - “How hard can it be? It's only wood!” |
622 days ago |
Dave , does yours have any shocks? Bob -- A mind, like a home, is furnished by its owner |
622 days ago |
I can’t remember where I stole this image from; it may appear elsewhere on LJ. Whatever, it fits nicely with this topic.. -- Res severa verum gaudium - True pleasure is a serious business. http://www.folksy.com/shops/TreeGems |
622 days ago |
Thanks all for your suggestions. A trailer would be overkill for me, as I only buy sheet goods occasionally so a more sensible solution would be to use the roof rack. It’s not flat but I could make some sort of support that would go on top of it. -- Nick, Fremont, CA. |
622 days ago |
Would anybody really load a car like that? That’s a pretty big load for a pickup truck! Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
622 days ago |
As far as getting sheet goods for myself, I either have them delivered, or in a pinch I pick them up in a van. I know that 5’ x5’ baltic birch problem. That’s part of the reason I stopped using it. The real reason is I found Maple Apple Ply, which has a far smoother surface, is available in 9 or 13 ply in 1/2” thickness, and comes in standard sized sheets. I like this far better than baltic birch, which I used to swear by. I would take a cordless circular saw and rip it in the parking lot, so it would fit in my van. Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
622 days ago |
you can rent a truck from Uhaul for 19 a day plus miles. Home Depot and Lowes usually ahve a cheap rental too. Also, find a friend with a truck… -- making sawdust.... |
622 days ago |
Hey Nick, My problem is not transporting the plywood (I have a truck), but it is fitting it through the door and managing a whole sheet in my shop. When I need to build a cabinet or carcass I spend a lot of time carefully planning the cuts before I go to the lumber yard. Then I have them cut the sheet on the spot. If I need to be extra precise, I have them add an inch to all dimensions and then I can make the final cuts on my table saw and I am able to work with smaller pieces that way. -- Check out my new website! http://www.blakeweberwoodworking.com |
622 days ago |
YorkshireStewart, I’ve got roofracks, and my car has looked dangerously close to that… -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
622 days ago |
Blake and I follow the same path. I have an SUV that barely fits 4’ width and will not take a 4×8 sheet in one piece. Lee -- No piece is cut too short. It was meant for a smaller project. |
622 days ago |
I do the rental truck thing. It adds to the cost, but I usually buy a lot at the same time to spread the cost over several projects. The rental keeps the friends truck in tact and ready for something more important – like moving. -- You can't get a hug from Facebook. |
622 days ago |
Since you have an SUV, does it have a trailer hitch? It was mentioned to rent a truck or buy a trailer, why nbot rent a u-haul trailer. A truck costs by the mile, a trailer doesn’t : one flat rate for the whole day. I am lucky enough to have a dad that owns a wx8 trailer, but before that I rented a uhaul trailer. -- Brian, Lebanon PA, If you aren’t having fun doing it, find something else to do. |
622 days ago |
Blake, Lee, I can’t get a trailer rental, I don’t have a trailer hitch. It’s probably not that expensive but I typically buy only a few sheets at a time as my projects are few and far apart. Thanks all for your replies. -- Nick, Fremont, CA. |
621 days ago |
I have a trailer, and it has been so useful for this and so many other things that it justified the expense. |
621 days ago |
I love the loaded car pic! I am thinking of how many times I have seen ply in the middle of the road or on the side of the road from ppl. that loaded ply on top of these kind of roof racks designed for luggage. the thought of the weight was concidered but the wind load and lifting aspect as they traveled at even low speeds was not. Ripped off luggage racks and repair was not figured into the material list…..Good Luck! -- Can't never could do anything, to try is to advance. |
621 days ago |
Man, I know the feeling on this one. When I was in college I had a nice big pickup (lived in Oklahoma and you got issued one with your driver’s license). When I moved to Kansas City, the gas just didn’t make sense anymore and I dropped it off at my parent’s house and bought a 4 door Grand Am. Now, I’m a home owner and I wish the truck was still running enough to use. Case in point: I had a smallish fence project to complete two weeks ago and went to HD to get the materials I needed. My shopping list was: 15 6ft Uposts, 2 Bails of 100ftx4ft welded wire, 1 post driver, 1/2 mile role of electric fence, and 2 portable saw horses. Funny thing is, I got the whole damn mess in the car and drove home safely!!! As far a sheet goods go, I do the same thing but have the guys use the nice panel saw in the lumber yard to get it done. My wife and I have been back and forth on what to actually do to make the trip make more sense for large sheets. We have thought trailer (but I don’t have a hitch on the car or a good towing capacity), we thought rental (but we never buy enough to make the rental make sense), and we have even thought of buying a old piece of crap truck to use for this one task. Final solution? I was telling my dad about a particularly embarrassing moment in the parking lot of HD when not only could I not get the sheets to fit but I kept chasing them because of the wind and he offered to get my truck running and drive it back to KC for me. Of course, that was in November and it still hasn’t happened yet. Alas… ~DB P.S.: Oh, Narayan, I would think really hard about adding spacers between the boards to let air through. Basic aerodynamics would suggest that the increase surface area would actually make it more likely to take flight. You run the risk of multiplying your 32sqft of lift to however many you are hauling. I would hate to be the guy behind you who had to watch and then dodge the pieces!!! -- He said wood...http://hickbyassociation.blogspot.com/ |
621 days ago |
Adding to the comments to Narayan, once or twice I’ve bought an extra sheet or two of cheap 5/8 ply to sandwich the stuff I’m really carrying. If I’ve got space to store it there’s always a use for it, and it protects that veneered 1/4” panel or whatever else nicely. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
621 days ago |
Standard OE roof racks are useless for heavy 3/4 plywood, Yakima rack is a good product but still would limit the load to 2-3 sheets. I clamp the sheets together in the front with a c-clamp then tie that down to the front bumper. Keeps the air from getting up under the boards and taking off like a bird. At least that’s what I did till I got a truck. -- DocK, WV |
620 days ago |
If you want to see some fodder for funny videos just hang around in the BORG parking lots. The oddest one that I ever observed was this couple trying to tie a 4×8 sheet of plywood in the trunk of their car! The worse one was a pile of wooden pallets sitting in the middle of four lanes of heavy traffic. You should have seen the stuff fly when a truck hit those pallets. I was very happy I was in the far left lane! -- Jim |
620 days ago |
620 days ago |
Actually, if you are limited by car size, you should check this out. It may not carry much weight, but you have to admit the person was thinking when they designed it… -- He said wood...http://hickbyassociation.blogspot.com/ |
620 days ago |
I have been tempted to haul 4×8 sheet goods secured to my roof rack (rated at 75lbs). I have always found a way around having to do it. Friends trucks, cutting the sheet goods down to fit inside the vehicle. I also know there are times when a full sheet is what is needed. It seems if the weather conditions are good, driving distance short, low surface street speeds, load is secured front and back maybe clamped to a couple of 8’ 2×4’s, it may be a “reasonably safe”. Dalec |
620 days ago |
I’ve had several hundred lbs on my roofrack (2 6 seat + guide whitewater rafts and a couple of kayaks), so weight isn’t the problem, but as Suz points out, most people don’t know how to tie down a load. Especially with big things that’ll catch the wind, it’s important to run lines around both the front and the back of the load, but also to tie to attachment points on the car frame, because the little clips the racks use to attach to the door frame, or even the rain gutters on cars so blessed, aren’t sufficient for real loads. In fact, I’m so confident in my load securing abilities that I once drove 200 miles (Fresno to Marin up 99 and over 580) with a Cannondale tandem bicycle and $3500 in brand new Festools in boxes tied to my roofracks. The roofrack payload well exceeded the value of the car. I’ve been considering one of those cheap Harbor Freight trailers, I think for a few hundred bucks they’re light enough that I could lean ‘em up against a shed in the back yard, and could be perfect for those runs to Mount Storm lumber when I don’t want to take all of the bicycle hardware off my racks. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
577 days ago |
I do have the folding trailer shown by Bob #2 above. I got mine at HF for $200 in sale. Be sure to get the one with 12” tires, gross weight is 1450 lbs. The trailer only weighs 200+ lbs, easy to move around by hand and does a good job for hauling the things that won’t fit in the SUV. -- If you don't make mistakes, your not trying! |
577 days ago |
I dont have any good suggestions for an SUV or car, but as far as a truck goes… Even a small truck can haul full sheets. As long as you have the holes in the top of the bed sides for tie downs/etc. I don’t know if I can explain it well enough typing, so I may do it in sketchup when I get home (time permitting). Just simply make a low rack that fits in your tie slots on top of the bed sides with a wooden rail going down each side of the bed. You can use loop screws (surely that’s not the correct term, but they are the screws you use for hanging a swing) to ratchet strap the rack to the bed securely, and then use a couple more as anchors for another strap or two to keep the sheet goods from slighting front to rear. That may not make any sense at all, but it is easy to build and works well. If more explanation is needed I can draw it out. -- Location: Birmingham, AL - Stimulate this Mr. President! |
571 days ago |
I received the V’dub pic many years ago with the story. The lumber on the roof is only part of the story. They also had bags of quickcrete inside the car! Supposedly they actually drove the top of the rear struts through the body! And for the record, I have a relatively large SUV, (Suburban) and once I got my junk trailer I have yet to put lumber in my truck. The trailer is a 3/4 ton Chevy rear end turned into a trailer. I have 4 2×4s with stops I put on the rails for lumber and sheet goods. I was lucky to get the trailer for free, and just had to put on new rubber, tail lights and a safety chain. cheers, -- Tom - Canadian in N. Texas |
| Forum | Topics |
Woodworking Skill Share
2937 |
3968 |
260 |
956 |
226 |
Woodworking Trade & Swap
624 |
Coffee Lounge
2403 |
LumberJocks.com Site Feedback
525 |
