Equipment SAFETY tips: The Planer
Forum topic by MsDebbieP posted 788 days ago 1555 views 0 times favorited 20 replies Add to Favorites Watch
18335 posts in 2358 days
788 days ago
Topic tags/keywords: safety tips planer
Safety in the shop tips for the planer.
What are some tips to work safely on and around a planer?
(See all SAFETY TIP GATEWAYS here)
20 replies so far
View chrisstef's profile (online now)
chrisstef
5570 posts in 1203 days
#1 posted 788 days ago
one vote here for ear protection.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View bubinga's profile
bubinga
860 posts in 865 days
#2 posted 788 days ago
Pinch Points
-- E J ------- Always Keep a Firm Grip on Your Tool
View devann's profile
devann
1711 posts in 889 days
#3 posted 788 days ago
Two goods ones above. Add remove jewelry, secure loose clothing and long hair.
#4 posted 788 days ago
What does “pinch points” refer to?
View Walnut_Weasel's profile
Walnut_Weasel
360 posts in 1419 days
#5 posted 788 days ago
I am guessing pinch points would refer to how it is possible to get you fingers trapped between the board and the table and/or sides of the planer as the board is being feed by the power rollers. (Wow that was one long sentence!)
I would have to also add kick back even though it is unlikely due to the safety features on most planers.
-- James - www.walnutweasel.wordpress.com
View lew's profile
lew
9035 posts in 1952 days
#6 posted 788 days ago
Stand to one side of the planer during operation in case a piece shatters and the planer ejects the broken pieces.
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
View Dennisgrosen's profile
Dennisgrosen
10851 posts in 1312 days
#7 posted 788 days ago
use pushsticks and fetherboard
take care
Dennis
View spanky46's profile
spanky46
969 posts in 1587 days
#8 posted 788 days ago
Safety glasses!
-- spanky46 -- Never enough clamps...Never enough tools...Never enough time.
View cabmaker's profile
cabmaker
1050 posts in 1006 days
#9 posted 788 days ago
If its not a floor model make sure it is secured to bench or other. Keep outfeed path clear. Oh and do not stick body parts in the machine.
17950 posts in 2048 days
#10 posted 788 days ago
Don’t forget the ear & eye protection & push sticks to preserve the fingers
View ajosephg's profile
ajosephg
1726 posts in 1758 days
#11 posted 788 days ago
Keep the floor and surrounding area not cluttered. Unlike most other shop equipment you must walk from the front to the back while it’s running. If you trip or stumble bad things could happen.
-- Joe
12168 posts in 1538 days
#12 posted 788 days ago
out feed boards droop
and can catch on the edge of tools or workbenches
making the planer walk up the board
and fall over backwards
or bow the board so bad it breaks
and sends splinters flying
View Roger's profile
Roger
9482 posts in 1001 days
#13 posted 787 days ago
take very light passes. takes a bit longer, but, much safer and easier on your knives
View HorizontalMike's profile
HorizontalMike
5592 posts in 1111 days
#14 posted 747 days ago
NO loose clothing (could even be a shop apron or dangling tie cords, etc.) and NO gloves or the like to get caught on and/or pulled into the auto-feed pinch points that bubinga refers to.
bubinga
#15 posted 747 days ago
A pinch point could also be a board coming out of a planer ,and pinching your body, or a body part,against another object ,that you did not realize was close enough for that to happen, or is not usually there.
Feeding a shorter board ,when the planer grabs it , can pinch your hand,or fingers between the board ,and table.Potential Pinch points are every where in the shop.
Any where, any thing that can get pinched
Don’t slam your foot in the door on the way out
