Need a photo - ridgid oscillating belt and spindle sander
Forum topic by leftcoaster posted 03-04-2018 09:09 PM 405 views 0 times favorited 2 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
230 posts in 1082 days
03-04-2018 09:09 PM
Can someone post a close up photo of the belt piece of this sander ? Specifically how the washers, spring, and other parts are supposed to be placed on the knob at the narrower end. Mine came apart and the diagram doesn’t show this particular area exploded.
2 replies so far
View Stevedore's profile
Stevedore
73 posts in 2231 days
#1 posted 03-04-2018 11:10 PM
Does this help? There’s another washer between the spring & the frame. (upper end of the spring in the photo)
Going from the knob, it’s large washer, small washer, frame, small washer, spring.
-- Steve, in Morris County, NJ
leftcoaster
#2 posted 03-05-2018 02:50 AM
Steve, thank you! There was a tiny rubber washer that I slipped over the threads and that prevents the small washer inside the frame from dropping off if the bolt is removed.
Thanks a ton – really appreciate it.
