Drill Bits
Forum topic by ChicksWithTools posted 03-04-2018 07:48 PM 786 views 0 times favorited 20 replies Add to Favorites Watch
View ChicksWithTools's profile
ChicksWithTools
48 posts in 731 days
03-04-2018 07:48 PM
Topic tags/keywords: question
I just finished a simple project of putting new hardware on a dresser which required small pilot holes. After killing all my 1/16” titanium coated drill bits in a Ryobi drill bit kit, does anyone have a recommendation of brands/types that don’t break so easily?
Thanks
-- Courageous convictions will drag the dream into existence. - Rush, Vital Signs
20 replies so far
View caboxmaker's profile
caboxmaker
281 posts in 502 days
#1 posted 03-04-2018 07:50 PM
1/16” drill bits break easily. I bought a pack of a dozen just because of that.
caboxmaker
#2 posted 03-04-2018 09:08 PM
Here’s an example from Amazon.
ChicksWithTools
#3 posted 03-04-2018 10:13 PM
That’s better than the Home Depot party pack price
View MrUnix's profile
MrUnix
6882 posts in 2313 days
#4 posted 03-04-2018 11:51 PM
+1 for buying them in bulk. 7 piece set at HF is $1.99 and are as good as any.
View pontic's profile
pontic
625 posts in 723 days
#5 posted 03-04-2018 11:55 PM
I second the HF purchase. Use low pressure and lower speed with those little guys.
-- Illigitimii non carburundum sum
View Andre's profile (online now)
Andre
2006 posts in 1920 days
#6 posted 03-05-2018 12:02 AM
I have used a small hand powered drill for a lot of smaller drilling jobs, sort of like a jewellery’s drill but a little bigger.
Lee Valley sells a couple of different types, and of course breakage still possible!
View waho6o9's profile
waho6o9
8343 posts in 2691 days
#7 posted 03-05-2018 12:09 AM
View Walker's profile
Walker
146 posts in 586 days
#8 posted 03-05-2018 12:11 AM
*bookmarking things from this thread
Usually when I need a small hole I’ll break the 1/16” bit, and the spare, then break both 5/64th bits, then the 3/32 bit, then throw whatever I was working on at the wall and break that too.
-- ~Walker
ChicksWithTools
#9 posted 03-05-2018 12:22 AM
I didn’t consider HF as my brother says “Friends don’t let friends shop at Harbor Freight” but I did sneak in there without his knowledge and buy some clamps. I guess if its an item that breaks easily not matter which brand, then the cheapest party pack works :)
View Rayne's profile
Rayne
1025 posts in 1654 days
#10 posted 03-05-2018 12:35 AM
I didn t consider HF as my brother says “Friends don t let friends shop at Harbor Freight” but I did sneak in there without his knowledge and buy some clamps. I guess if its an item that breaks easily not matter which brand, then the cheapest party pack works :)
- ChicksWithTools
HF has its place and if you know what to look for, you can save a TON without sacrificing much on quality, if any.
View Woodknack's profile
Woodknack
12329 posts in 2494 days
#11 posted 03-05-2018 12:38 AM
Dull bits require more pressure which flexes the bit breaking it; and cheap bits are dull. Just be extra careful and/or buy high quality bits that cut easier and cleaner. I bought some US made bits and they cut wood like it’s butter.
View Richard Lee's profile
Richard Lee
145 posts in 889 days
#12 posted 03-05-2018 12:50 AM
As a 45 year Machinist I know that the biggest cause of drill failure is runout,then not keeping it straight while drilling.
Then not clearing the flutes and burning.
1/16 drills need the correct RPM for the job and need to have the swarf cleared and need cooling or oil,if your drilling metal.
Probably nothing wrong with your bits,all you are drilling is wood. Misalignment is your problem.
runswithscissors
2818 posts in 2139 days
#13 posted 03-05-2018 04:26 AM
HF cobalt bits are as good as anybody’s, in my experience. But I’ve found all cobalt bits a bit brittle. I have to replace mine as they break.
But 1/16” seem awfully tiny. What kind of hardware attaches with fastenings that small? Some of my drill chucks won’t even grip a bit that small.
View BoardButcherer's profile
BoardButcherer
144 posts in 208 days
#14 posted 03-05-2018 01:32 PM
HSS and black oxide bits. They don’t have to be the sharpest bits ever, we’re working in wood, and those two are typically much more flexible than other materials which means you get a little more oops factor before it snaps like dry spaghetti.
View ScottM's profile
ScottM
671 posts in 2261 days
#15 posted 03-05-2018 02:20 PM
- ChicksWithTools
I consider HF my “disposable products” source…
