Slow speed grinder on the fritz
Forum topic by Ben posted 03-04-2018 05:22 PM 229 views 0 times favorited 5 replies Add to Favorites Watch
View Ben's profile
Ben
376 posts in 2879 days
03-04-2018 05:22 PM
I have a Woodcraft slow speed grinder – about 9 years old and seen very little use.
Recently it comes on, spins at a very slow speed for maybe 10-20 seconds, sort of whiny, then stops with the motor whining.
Any ideas on how to fix?
Thanks.
5 replies so far
View MrUnix's profile
MrUnix
6757 posts in 2221 days
#1 posted 03-04-2018 06:05 PM
Whining sounds like bearings going bad. Open it up and check.
View Lazyman's profile
Lazyman
2036 posts in 1409 days
#2 posted 03-05-2018 12:54 PM
If you spin it by hand is there any resistance or noise? If not, my guess would be the capacitor is bad.
View BoardButcherer's profile
BoardButcherer
144 posts in 116 days
#3 posted 03-05-2018 01:27 PM
Bench grinders don’t usually have capacitors, do they?
My bet is on a broken wire coming off of the commutator. If it wasn’t attached well just warming up and cooling off in your shop for 9 years could’ve caused it to pull loose.
Lazyman
#4 posted 03-05-2018 01:49 PM
Bench grinders don t usually have capacitors, do they?
My bet is on a broken wire coming off of the commutator. If it wasn t attached well just warming up and cooling off in your shop for 9 years could ve caused it to pull loose.
- BoardButcherer
Yes. The capacitor is usually in the base or behind the switch.
BoardButcherer
#5 posted 03-05-2018 02:24 PM
- BoardButcherer
- Lazyman
Thanks. Never had to break one down.
