Which Dust Collector to Buy?
Forum topic by wthwaites posted 03-04-2018 04:33 PM 402 views 0 times favorited 8 replies Add to Favorites Watch
View wthwaites's profile
wthwaites
5 posts in 106 days
03-04-2018 04:33 PM
Topic tags/keywords: dust collection
Hello All,
I have a small workshop and no dust collection system in place.
I have decided to go with a wall mounted system, but am having troubling deciding on which system to purchase.
Can anybody please advise which of the following is best:
1. Dust Right Wall Mount Dust Collector
2. Powertec Wall Dust Collector
3. Shop Fox Wall Dust Collector
What are the differences between the three brands/models, and which is the best choice???
Thanks much!
8 replies so far
View Woodmaster1's profile
Woodmaster1
980 posts in 2609 days
#1 posted 03-04-2018 04:38 PM
Make sure you get one with a pleated filter. It does a better job of filtering dust out of the air and they are easier to clean. I would also make or buy an air cleaner as well.
wthwaites
5 posts in 106 days
#2 posted 03-04-2018 05:45 PM
- Woodmaster1
Thanks for the feedback.
Can you give your opinion on which one of the models I listed is best?
View Mattg43's profile
Mattg43
6 posts in 129 days
#3 posted 03-05-2018 12:24 AM
I have no experience with any of these mentioned, but…
Why not the Harbor Freight version? It seems they are all about the same motor, with a bag. With a 25% off coupon, the 2hp HF would be $150, or the small 1hp version (on wheels, but should not be hard to wall mount it if desired) would be about $110.
View Knockonit's profile
Knockonit
376 posts in 224 days
#4 posted 03-05-2018 01:28 AM
go up in right hand corner where it says ’’search’’ and put in dust collector, a plethora of info will arrive, all you have to do is read it, almost every avenue for dust collection known at this moment is there, only new stuff will be what you put in once you begin, as you may find a better, faster, cleaner way of dust colllecting, its one thing that everyone attempts to inprove on. good luck
Rj in az
View 01ntrain's profile
01ntrain
255 posts in 1093 days
#5 posted 03-05-2018 01:38 AM
Not sure what your setup is, and how many machines you’re going to run, but if it was me….I’d run it thru a Dust Deputy system, if it will handle the capacity. The wall bag can be used to filter out the fine dust.
As far as recommendations, they’re all pretty much the same machine. The specs on the Rockler say 650 cfm, but I highly doubt that. I’d go with the cheapest one.
wthwaites
5 posts in 106 days
#6 posted 03-05-2018 04:24 AM
- Mattg43
A customized version with the 1HP harbor freight motor could also be an option. I’ll definitely consider that as well…
wthwaites
5 posts in 106 days
#7 posted 03-05-2018 04:26 AM
Not sure what your setup is, and how many machines you re going to run, but if it was me….I d run it thru a Dust Deputy system, if it will handle the capacity. The wall bag can be used to filter out the fine dust.
As far as recommendations, they re all pretty much the same machine. The specs on the Rockler say 650 cfm, but I highly doubt that. I d go with the cheapest one.
- 01ntrain
Yes, I intend on getting a dust deputy as well for a 2 stage system set up.
Thanks for the advice!
wthwaites
5 posts in 106 days
#8 posted 03-05-2018 04:39 AM
- Mattg43
Thanks for the information. I read that the harbor freight model is excessively loud; so, I was hoping to hear that one of these models would be a lot quieter. But, if they are more or less all the same in terms of noise level, maybe the equivalent harbor freight model is the way to go…
