Old Hand Plane Blades?
Forum topic by Chris_T posted 760 days ago 974 views 0 times favorited 8 replies Add to Favorites Watch
View Chris_T's profile
Chris_T
94 posts in 961 days
760 days ago
I recently bought a Stanley #5 hand plane on Ebay. The blade has a pretty significant ding it it. I would say it is 1/16”-1/8” deep. What would be the best way to get rid of it.
8 replies so far
View WayneC's profile
WayneC
9596 posts in 2264 days
#1 posted 760 days ago
Have a bench grinder and something to keep the blade cool?
View pete79's profile
pete79
154 posts in 1307 days
#2 posted 760 days ago
IMO – the “best” way would be to replace it with a new Hock blade.
-- Life is a one lap race.
WayneC
#3 posted 760 days ago
Or one from Lee Valley.
http://www.leevalley.com/en/wood/page.aspx?p=66868&cat=1,41182
BTW. I am a Hock user, these are a new offering and I have not used them. They have been reviewed on the LJ site.
Chris_T
#4 posted 760 days ago
I would like to keep the original blade. I guess I’ll be grinding it.
View DaleM's profile
DaleM
800 posts in 1551 days
#5 posted 759 days ago
I had one like that. I fixed it by hand, starting with 60 grit sandpaper and working my way up. It takes a little time, or a lot of time depending on the blade, but at least I knew I wasn’t overheating the blade by using the grinder.
-- Dale Manning, Carthage, NY
View rance's profile
rance
3856 posts in 1327 days
#6 posted 759 days ago
You might consider a ‘sharpening service’ like what you use to get your table saw blades resharpened.
View David Kirtley's profile
David Kirtley
1250 posts in 1165 days
#7 posted 759 days ago
You can’t really hurt it. Just don’t overheat. Grind slow and cool it off often.
If you are not comfortable yet grinding away on a plane iron, a stock #5 blade is $15 new. I can’t see a high dollar blade for a jack. If you work with squirrelly wood a high dollar blade makes sense for a smoother. I could make a case for one in a jointer.
View Jim Jakosh's profile
Jim Jakosh
7250 posts in 1272 days
#8 posted 759 days ago
Slowly grind the edge clean without overheating it by hurrying. Then hone it on a whetstone or diamond hone.
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
