Leeson motor rewiring? 220v-110v?
Forum topic by CartersWhittling posted 04-21-2011 02:20 AM 3643 views 0 times favorited 3 replies Add to Favorites Watch
View CartersWhittling's profile
CartersWhittling
453 posts in 2636 days
04-21-2011 02:20 AM
Topic tags/keywords: question
Hello. I have a table saw with a motor that is set up with to run 220. I want to rewire the motor to switch it over to a 110v. The man who gave me the saw said that it was 110 and he had switched it over to 220v, but he does not have the electrical diagram to show me how to rewire it. Does anyone know how I could find a diagram on the internet or how to rewire it to change it to a 110v. Its a Leeson motor, model number M6C34FB8C.
-- And whatsoever ye do, do it heartily, as to the Lord... Colossians 3:23
3 replies so far
View klassenl's profile
klassenl
185 posts in 2621 days
#1 posted 04-21-2011 05:41 AM
If you can take a picture of the wires and the inside of the cover(s) then maybe we can lend a hand.
-- When questioned about using glue on a garbage bin I responded, "Wood working is about good technique and lots of glue........I have the glue part down."
View ScottN's profile
ScottN
261 posts in 2642 days
#2 posted 04-21-2011 10:36 AM
did you pull the cover plate off the motor? the wiring procedure should be on the back side of the cover.
-- New Auburn,WI
CartersWhittling
#3 posted 04-21-2011 11:56 PM
I did take the motor cover plate off but its not there, the man who owned the saw before said the diagram should have been on there.
