Tilting table saw issues
Forum topic by Dazz posted 03-03-2018 01:48 PM 477 views 0 times favorited 5 replies Add to Favorites Watch
View Dazz's profile
Dazz
1 post in 290 days
03-03-2018 01:48 PM
Topic tags/keywords: tablesaw tilting unevenly
Hi! My first time here. Hope someone can help.
When I tilt my blade it is not tilting evenly. Eg. the back of the blade moves further than the front. I thought the arbour may be bent, but that would mean the difference would swap to the front on rotation of the blade. The issue is always with the rear of the blade. I own a Carbatec 10” contractor saw. All suggestions of possible causes would be much appreciated. Cheers
5 replies so far
View Gene Howe's profile
Gene Howe
11079 posts in 3634 days
#1 posted 03-03-2018 03:03 PM
Sounds like either the belt is pulling it out of line or the tilting mechanism is wonky. Possibly mounted slightly crooked?
View johnstoneb's profile
johnstoneb
3064 posts in 2378 days
#2 posted 03-03-2018 03:06 PM
I think you need to check the alignment of the saw especially get blade in alignment with miter slot.
-- Bruce, Boise, ID
View Woodknack's profile
Woodknack
12431 posts in 2585 days
#3 posted 03-03-2018 05:43 PM
Sounds like the same problem that afflicted Ridgid and Craftsman saws. If it is, nothing you can do.
View oldnovice's profile
oldnovice
7337 posts in 3573 days
#4 posted 03-03-2018 08:16 PM
It it possible that the pulleys are making contact with the blade insert when tilting the arbor?
That is what I found on my TS.
Another issue with my old Craftsman 10” TS was that the tilt mechanism is attached to the sheel metal side which flexes more as the angle increases!
Just some random thoughts!
View jgtb's profile
jgtb
3 posts in 251 days
#5 posted 04-11-2018 10:06 AM
Hi there – I’m no expert, but it sounds like an alignment issue where the tilting mechanism’s axis is at an angle to the saw table.
This kind of misalignment is discussed on the last page of this free Fine Woodworking article:
http://www.finewoodworking.com/membership/pdf/241305/011265048.pdf
The article talks about cabinet saws, however, since you have a contractor saw, you may need to shim the arbor assembly where it bolts to the bottom of the table to get the tilt axis parallel to the top of the table saw front-to-back.
Hope this was helpful.
Johan
