Please help me with my 14X18 shop
Forum topic by agallant posted 04-20-2011 03:34 PM 3107 views 0 times favorited 27 replies Add to Favorites Watch
View agallant's profile
agallant
551 posts in 2880 days
04-20-2011 03:34 PM
It seams like every few months I go through this fit where I reorganize my shop, moving tools and what not, I can never get it to a place where I am 100% happy with my work space. I am open to all advice and photos of other peoples shops that are around the same size. I will post some photos of mine later today.
-AG
27 replies so far
View therookie's profile
therookie
887 posts in 2820 days
#1 posted 04-20-2011 03:43 PM
My suggestion is go to the shops section of the webpage and look at all of the different examples.
-- http://aewoodworks.webs.com
View Jack_T's profile
Jack_T
623 posts in 3024 days
#2 posted 04-20-2011 03:56 PM
My suggestion is to pack all of your tools up and send them to me. I promise to send the ones I don’t want back. Only kidding of course. I will check back later to see your photos. Therookie has a good idea.
-- Jack T, John 3:16 "For God so loved the world that he gave his only Son, so that everyone who believes in him might not perish but might have eternal life."
agallant
#3 posted 04-20-2011 03:58 PM
I wish the shop section would include size
View Ripthorn's profile
Ripthorn
1458 posts in 2978 days
#4 posted 04-20-2011 04:02 PM
I have a shop a little narrower and a little longer. The key points are table saw in the center oriented with the length of the shop (I have the 7 ft rails with extension table). Jointer goes along one short wall with the work bench along the other. I have wood storage, bandsaw, and drill press along the long wall. Miter saw lives under the ts extension table and benchtop planer lives under the workbench. I might be able to get a pic, we’ll see.
View skippyland's profile
skippyland
158 posts in 2685 days
#5 posted 04-20-2011 04:08 PM
Dude, I feel your pain…my stand alone shop is 12×20 and very cramped. The double doors help when I need to rip a long piece on the TS, but if you check my fotos, you’ll see ALL wall space is covered and I utilize locking caster bases alot. I think at some point a decision has to be made as to what types of wood working can you handle and then probably do the best with those tools. In the beginning, my “best woodworking” was spending money on tools. Too much clutter can be dangerous. Best of luck!
-- Skip from Batavia, purveyor of fine and exotic sawdust & chips.
View dbhost's profile
dbhost
5708 posts in 3225 days
#6 posted 04-20-2011 04:23 PM
Since you weren’t kind enough to post up a workshop profile to give us a clue what you are dealing with, my only answer to you is, organize it.
I can throw some generalities out there that may help you though…
For starters, be grateful for what you have. 14×18 is MUCH larger than the shops a lot of guys have. There are more than a few folks on here that are working out of 8×10, and 10×12 sheds… What you have must seem cavernous to them…
Unless you are filthy rich, life outside of any HOA, and or are just flat lucky enough to have a spare large building on your property, chances are, as a woodworker, you are trying to eke shop layout and storage out of every cubic inch of shop you have. And probably have a little spillover into other areas of your home / property… So take a gander at the suggestions below and see if any of them help…
#1. Do you have any tools on steel legs? Convert the open space on the legs to storage by boxing it in, or replace the legs with a cabinet to house all the accessories for the tool. #2. Do you have a stand alone router table? Lose it. Replace it with a router table in a table saw extension wing, either shop built, or commercially produced… #3. Got everything neatly organized across the wall on peg board? Don’t do that! Instead build storage cabinets such as clam shell cabinets with peg boards on them. That way you multiply your peg board storage space while utilizing a small fraction of the wall space you had been. #4. Use space under things like table saw extensions for roll away cabinets, or other tools. Mine has a shop vac and a 20 gallon Thien cyclone separator under there… #5. Those plastic multi drawer bins sold at office stores and Walmart etc… make great separators / organizers for sandpaper and similar materials. #6. Build some sort of stacking system for your bench top power tools, unless your back just can’t take it. If you want to know what I am talking about, look at the Best Home Workshop Ideas 2011 for one take on it, or look at my shop for another. I went the simple route, Wood Magazine’s version is prettier, and doesn’t occupy wall space. Take your pick. #7. Take some time and review the workshops posted here. There are a TON of great ideas that the guys and gals here have posted up for saving space… #8. Opt for smaller versions of tools that you can afford to go smaller on. A bench top jointer takes up far less space than a floor model. But you sacrifice bed length and mass. A small 9” bench top band saw likewise takes less space than a floor model 14” or so on… You get the idea… #9. Learn to use Google Sketchup, and lay out your shop space in 3D before you give yourself a hernia…
For what it’s worth, probably your best resource for ideas is just to spend some quality time perusing the shop tours here. There are a ton of excellent shops, just dripping with good ideas, and some with not so good ideas… It can be very inspirational to see how somebody else solved a similar problem to what you are dealing with…
117085 posts in 3570 days
#7 posted 04-20-2011 04:30 PM
this might help
http://grizzly.com/workshopplanner.aspx
View bsherman's profile
bsherman
76 posts in 3521 days
#8 posted 04-21-2011 06:07 PM
My shop is almost exactly the same size. You might see some things that are helpful on workshop / projects pages. After some time, I ended up putting pretty much everything on wheels. Which still didn’t help much because of the big tablesaw/outfeed in the center. The thing that made the biggest difference was having the tablesaw on wheels, and building an outfeed that can pop up so the tablesaw can slide under. That way the whole thing can be nested and moved out of the way, and I can have a fairly large space when needed. Good luck.
-- Brian
View pinebarron72's profile
pinebarron72
25 posts in 2630 days
#9 posted 04-21-2011 06:13 PM
I have a 12×16 shop..with very high ceilings! I have a nice set up…email me and I will share my photos. I use my shop for wood working and lawn equip storage. pinebarron72@gmail.com
-- I Like Saw Dust---Matt Simmons
View rickf16's profile
rickf16
390 posts in 3574 days
#10 posted 04-21-2011 06:31 PM
14×18, 12×20… I would be in heaven with a shop that size! I’m in a 10×12 and don’t dare even sneeze without the doors open:) I have used a lot of wall space and even the inside of the doors for a clamp rack. I understand about space as a premium. dbhost has some great ideas. The one about the clam shell cabinet is a good one. Will have to do that myself. I use a lot bench top tools. My router table is in my table saw, great space saver and I stay on the same side of the saw when using it. I have a dust collector mounted upside down on the wall.
-- Rick
agallant
#11 posted 04-21-2011 06:33 PM
sawblade1 sent me this I thought the info was so good that I am going to repost it here for everyone to see.
Good afternoon,
I was reading your posting about your small shop &
I have a small shop 12×16’ I have a few links of what works here are they
http://www.workbenchmagazine.com/main/wb297-homeshop04.html
http://www.workbenchmagazine.com/main/wb297-homeshop05.html
This shop is 50 Sq ft just a little under half of mine I am working on making modifications to it to suit my taste and hopefully by summers end I will be
working on posting it (getting into my busy season, I build outdoor furniture) BTW here’s a list of what I have in there
Delta contractor tablesaw w/ bench dog router table mounted to it
12 dewalt compound mitersaw w/ 8’ kreg track
Delta 14” bandsaw
Delta 6” jointer
Delta hollow chisel mortiser
Delta 16” scroll saw
3 Dewalt Cordless drills 2 18 V 1 12v
Harbor freight drill press (bench top)
Porter cable disc/ belt sander
Delta Boss Spindle sander
Grizzly 10” drum sander
Planned tools
Delta Dust collector
Lathe ( bench Top )
More hand tools / router bits
Templates
I hope this helps If you need additional help Feel free to shoot me a PM and I will gladly help in my spare time.
God Bless
Sawblade1
View DrDirt's profile
DrDirt
4424 posts in 3735 days
#12 posted 04-21-2011 08:56 PM
Mine is 14 by 21. Everything is mobile – so I could clear the center of the room to build the 12 foot dining table. Also I can open the garage door. But I really really miss having a ~4 by 6 or so Assembly table rather than building on top of the unisaw.
You inevitably get stuff stacked then need to make a cut.
agallant
#13 posted 04-21-2011 09:04 PM
That is one of my biggest issues, using the TS as a work bench. I put some pretty good scratched in the top of my sawstop so I decided I need to reorganize the shop and find a better way.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3152 days
#14 posted 04-21-2011 09:39 PM
Even with a real workbench, the TS still gets used as an assembly table in such shops – my problem is glue and finish droppings. In those cases, you can either roll with it and devise a way to cover the TS…maybe an extension table with something that “folds back” to protect the TS top. Or, you can build a knock-down bench to use outside. I actually built two sturdy sawhorses that I use for various assembly projects…just set them right outside the garage door and get to work.
There’s just something about the size of our table saws…and their central locations…that makes them eminently functional as an assembly table. You have to replicate that some how if you hope to get away from it.
-- jay, www.allaboutastro.com
View redryder's profile
redryder
2393 posts in 3095 days
#15 posted 04-21-2011 11:23 PM
After looking at a lot of shops on this web site and doing an expansion on mine, I don’t think that size really matters. I went thru every nut and bolt and tool I own when reorganizing my shop. I found that I had six hammers, 35 screw drivers four sets of chisels, too many sets of lights and a ton of other crap I don’t need. The Goodwill, the recycling center and my wall space all benefited from my slimming down. DBHost is right that peg boards are just clutter catchers. All of my tools (wrenches, plyers, screwdrivers, sockets, hammers etc) are now in two stackable tool boxes and I have more wall space for cabinets to store glue, paint, sandpaper etc. I see some workshops that have more lumber stacked up than they do at the lumber yard. I am pretty sure the wood at the bottom of many of those stacks hasn’t been touched in years. I don’t use lumber racks because they just take up too much space. This is just me and every space and needs are different. Ya the collapsable outfeed table on my TS has helped out a bunch too…......
-- mike...............
