SCM Minimax T124 Copy Lathe
Forum topic by db366 posted 03-01-2018 11:25 PM 343 views 0 times favorited 0 replies Add to Favorites Watch
View db366's profile
db366
10 posts in 1452 days
03-01-2018 11:25 PM
Topic tags/keywords: lathe turning turn wood turning tools
Lathe is in great shape. Lots of extras. Comes with multiple extra custom machined steady rest supports, gouges have a ton of life left in them. No noise coming from any bearings. It’s a 110 lathe, made specifically for spindle turning. If you are into duplication this is the most affordable and best designed system out there it cuts off the backside so no chips fly at your face, everything goes towards the floor. The duplicator can be used along side your tool rest so you can easily switch between hand turning and duplicating. Can duplicate up to a 5×5 leg. It can turn up to a 16×16 round blank.
Pick up in Jefferson,ga. It’s heavy (about 500 lbs be ready to lift)
$2000
0 replies so far
