Rigid 4512 v Delta 36-725
Forum topic by Ian57 posted 03-01-2018 08:45 PM 1144 views 0 times favorited 45 replies Add to Favorites Watch
View Ian57's profile
Ian57
15 posts in 1817 days
03-01-2018 08:45 PM
Topic tags/keywords: question
Ok I know this question has been asked before. I am in the market for a new table saw, I have narrowed my choice down to these two models. Oh and before somebody throws the Grizzly G0771Z into the mix, I am not wiling to go the extra $400 this would cost.
I think I have googled all the possible pros and cons. The Rigid’s alignment issues, Delta’s not being repair friendly and I am still on the fence. Do I just make a choice and pay my money?
Can anyone help sway my decision, promise no comebacks
Cheers
Ian
PS I have posted the same question on other wood working forums
45 replies so far
View knotscott's profile
knotscott
8121 posts in 3493 days
#1 posted 03-01-2018 08:57 PM
Both have their fair share of knocks against them. Many times a good used saw is a better bet. Have you checked your local listings?
Ian57
#2 posted 03-01-2018 09:06 PM
- knotscott
I have and all I can find are either over priced or just junk. I will keep looking though. But I do like the idea of a warranty.
View Paul66's profile
Paul66
22 posts in 603 days
#3 posted 03-01-2018 09:10 PM
I went with the Delta 36-725 about a year ago and it has worked well for me.
At the time of purchase I really could have picked either one as the reported “issues” for both were not a major concern for me so it came down to “availability” and “current discounts”.
I’ve been very pleased with the saw, when using a “thin-kerf” blade. it will run through just about anything with ease
View MrUnix's profile
MrUnix
6887 posts in 2317 days
#4 posted 03-01-2018 09:14 PM
- Ian57
Everybody says that… mainly because the good deals come and go fast, so you never see them. It’s the overpriced or just junk stuff that stays out there :) Also, 99% of the time, if a machine is going to fail or have problems, it will do so in the first few weeks/months. An older machine has already been tested and proven.
View WhyMe's profile
WhyMe
1048 posts in 1679 days
#5 posted 03-01-2018 09:25 PM
I went with the Delta over the Rigid mainly because of the alignment issues with the Rigid at the time I was looking. I believe the alignment problem has now been eliminated. So it’s a six of one, half dozen of another choice. I like the fence on the Delta better then what’s on the Rigid. But I like that the motor on the Rigid is separate and not integrated with the arbor housing as with the Delta. I’ve had to deal with Delta a couple of times and had no real issue with their customer service and got what I needed. If choosing today I may have gone with the Rigid simply because of the motor not being part of the arbor housing.
View adr906's profile
adr906
10 posts in 220 days
#6 posted 03-01-2018 11:13 PM
I bought the Delta 36-725 about six months ago and have been happy with it. Woodworking is a hobby for me and it suits my needs. I was using a RAS before that.
knotscott
#7 posted 03-01-2018 11:33 PM
If you post your general location, someone here might have a lead on a good used saw.
Between the Ridgid and the Delta, I don’t have any clear insights that one is better than the other….there are pros and cons with each. I like the fence on the Delta better, but like “WhyMe”, I prefer the motor situation on the Ridgid. If necessary, the fence on the Ridgid can be fairly easily upgraded for a couple hundred bucks down the road….it might even work out ok for you.
Good luck, and please keep us posted on the outcome!
Ian57
#8 posted 03-01-2018 11:37 PM
Between the Ridgid and the Delta, I don t have any clear insights that one is better than the other….there are pros and cons with each. I like the fence on the Delta better, but like “WhyMe”, I prefer the motor situation on the Ridgid. If necessary, the fence on the Ridgid can be fairly easily upgraded for a couple hundred bucks down the road….it might even work out ok for you.
- knotscott
I am in Cocoa, Fl. I will update on my decision.
View woodworm1962's profile
woodworm1962
145 posts in 219 days
#9 posted 03-02-2018 12:04 AM
Stay… NO RUN from anything RIDGID! RUN RUN RUN! any other choice is better ANY!
-- No one likes the truth...
View cajunworkshop's profile
cajunworkshop
64 posts in 1113 days
#10 posted 03-02-2018 12:18 AM
Another vote for the Delta. Have had it about a year. Have had no issues. I am retired and in my shop 6-8 hours a day 5 days a week. Used it a lot and would buy again
-- Cajun Workshop Greenville, SC
View ppg677's profile
ppg677
192 posts in 974 days
#11 posted 03-02-2018 12:27 AM
The Ridgid R4512 is a great saw EXCEPT for the fence. The fence is flawed and can’t lock down repeatedly straight. The fence is upgradable.
So I would choose the Delta under the assumption the fence had got to be better.
Ian57
#12 posted 03-02-2018 12:54 AM
The Ridgid R4512 is a great saw EXCEPT for the fence. The fence is flawed and can t lock down repeatedly straight. The fence is upgradable.
- ppg677
That assumption about the fence seems to be backed up on the forums.
Ian57
#13 posted 03-02-2018 12:57 AM
- woodworm1962
Could you elaborate please.
View Woodknack's profile
Woodknack
12331 posts in 2498 days
#14 posted 03-02-2018 01:06 AM
Buy the Ridgid. The 5, 000 internet threads about alignment problems are just trying to trick you.
Ian57
#15 posted 03-02-2018 01:10 AM
- Woodknack
Sarcasm?
showing 1 through 15 of 45 replies
