Sparks on bandsaw
Forum topic by richgreer posted 766 days ago 1277 views 0 times favorited 13 replies Add to Favorites Watch
View richgreer's profile
richgreer
4474 posts in 1246 days
766 days ago
I’m using a 1/4” blade on my bandsaw and trying to cut a curve with a radius of 3.75”. I’m cutting through 6” of white oak. I’m getting some sparks from the blade. I’ve never seen this before.
Is this normal? If not, what could be the cause?
In advance of your responses let me say that I believe I have the right tension on the blade (20,000 lbs./square inch) based on my tension gauge (not the indicator on the side of my bandsaw).
All advice is appreciated.
13 replies so far
View blackcherry's profile
blackcherry
2906 posts in 1995 days
#1 posted 766 days ago
The blade teeth were hitting the guide bearing, to tight a turn in such a thick piece. You may need to set the guide bearing back a bit more…BC
View BigTiny's profile
BigTiny
1653 posts in 1060 days
#2 posted 766 days ago
Might also be mineral deposits in the wood.
-- The nicer the nice, the higher the price!
View TimKane2's profile
TimKane2
9 posts in 845 days
#3 posted 766 days ago
Having no experience, and essentially no knowledge of band saws except they cut stuff, 20,000lb/square inch sounds like an insane amount of force. That is a normal tension?
View wchips's profile
wchips
314 posts in 1260 days
#4 posted 766 days ago
could be sand on the wood or embedded in it
-- wchips
View William's profile
William
7109 posts in 1014 days
#5 posted 766 days ago
My old Craftsman 12” has guide blocks on each side of the blade. If I cut too tight a radius in wood, according to the thickness, the blade teeth sometimes will contact the guide blocks in a way to throw sparks.
richgreer
#6 posted 766 days ago
In response to TimKane2 – - I’ve read from several sources that 20,000 per square inch is right. You need to realize that a 1/4” blade has a cross section that is a very small percentage of a square inch. My calculations say that it is about .55% of a square inch. That implies a total pull on the blade of 110 lbs. That sounds reasonable to me.
View bubinga's profile
bubinga
867 posts in 840 days
#7 posted 766 days ago
Where exactly are the sparks originating from?
I saw sparks one time, when the blade broke and flew off, not fun
Actually had that happen with mineral deposits.
-- E J ------- Always Keep a Firm Grip on Your Tool
View gfadvm's profile (online now)
gfadvm
6655 posts in 862 days
#8 posted 766 days ago
I had sparks when my lower thrust bearing siezed.They obviously were below the table but the upper thrust bearing siezing would generate sparks above the table.I studied all the blade tensioning advice and use the 1/4” deflection and or the flutter technique.These have both been effective and simple to perform.You should be able to cut a much tighter radius with a 1/4” blade so I dont think that is the problem.I routinely cut 1” diameter circles with my 1/4” blade.
View Popsnsons's profile
Popsnsons
308 posts in 1153 days
#9 posted 766 days ago
Rich,
I had sparks come from the guide blocks. But when I run a Carter Stabilizer with my 1/4” blade the standard guides and bearings, both top and botttom, are not used and the operation is much smoother.
-- Pops ~ In So Cal...
View 000's profile
000
3352 posts in 788 days
#10 posted 765 days ago
you might have banged the teeth into a guide or maybe your turn radius is too tight for the kerf and width of the blade or you might have popped the blade out from the guides while trying to negotiate the turn and it scraped the guides somewhere it ought not to.
-- When the moderator chooses sides, his site sucks.
View Dusty56's profile
Dusty56
10541 posts in 1860 days
#11 posted 765 days ago
Hi Rich ,My first thoughts were mineral content or foreign objects , but you don’t mention if the sparks are before entering or when exiting the wood , but I’ll assume they’re up top because it would be impossible to see below the table while slicing. That would leave blade contact with the guides or bearings and not much else that I can think of.
Sorry.
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View Maddhatter's profile
Maddhatter
125 posts in 1749 days
#12 posted 765 days ago
Rich, have to agree with Dusty 56, with out knowing where the sparks came from it is hard to provide a recommendaton. most likely I would check the lower guide blocks as they can come out of adjustment and because they are below the table, you may not have noticed.
Hope all goes well. good luck and safe sawdust.
-- Norm (AKA - The Maddhatter), Middletown DE
View SteveMI's profile
SteveMI
806 posts in 1466 days
#13 posted 765 days ago
My band saw started making sparks at times and I found that one of the bearings had siezed. When cutting straight it was fine, but when trying to cut any kind of curve the blade contacted the bearing and caused the sparks. I changed the bearing and sparks went away.
Steve.
