turning with butt chisels
Forum topic by Joshy posted 04-20-2011 01:54 AM 1135 views 0 times favorited 6 replies Add to Favorites Watch
View Joshy's profile
13 posts in 2531 days
04-20-2011 01:54 AM
Topic tags/keywords: question
Has any one ever used butt and or bench chisels for between centers turning. I recently made a spring pole lathe, mostly from scrap boards, because money is kinda tight. I have learned that butt chisel will work if properly honed. I guess my question is (am I wasting my energy by using these chisels and are real turning tools that much more effective).
View papadan's profile
3584 posts in 3305 days
#1 posted 04-20-2011 02:09 AM
If they work for you then go with it. Normally a roughing gouge will work quicker at turning down a block, but if you can use something like a pair of vice grips to hold the chisel at an angle, you can do fairly well.
#2 posted 04-20-2011 02:40 AM
Thanks for the reply to my question. Have you ever used a spring pole lathe.
10116 posts in 3584 days
#3 posted 04-20-2011 02:43 AM
You can also grind old files to make woodturning scrapers. They work
pretty well because the file steel handles the heat from turning friction
Turning works best if you have a handle on the tool long enough to
put two hands on it.
I wouldn’t recommend using good bench chisels on a lathe – you
might break them or bend them badly. Just a concern. They
aren’t made for turning you know.
You ought to be able to get a used starter set of inexpensive turning tools
on ebay for $20 or something.
#4 posted 04-20-2011 02:49 AM
Joshy, I have never used a spring pole lathe, but have contemplated building one myself. Right now I have a Ridgid 12×37 and a little Jet 10×14. I make quite a few of my own chisels from different kinds of scrap metal. Just grind to shape and harden the working end. Make and install a handle on them.
#5 posted 04-20-2011 02:38 PM
Thank you for the information on making your own turning tools. I have a very old blacksmith forge and anvil. I also have some old rusty files, but how do you cut and or grind them? My dad has a lot of old railroad spikes, will those work? One more question, if any you were to recommend a few basic turning tool what would they be. I might break down and by some.
View poopiekat's profile
4337 posts in 3671 days
#6 posted 04-20-2011 04:00 PM
My first roughing gouge, which I made years ago, was a 18” piece of 3/4” black iron pipe. I ground the end to a bevel similar to what I’d seen in store-bought examples. It worked!!
