Lacquer or Liquior
Forum topic by woodworm1962 posted 02-28-2018 11:53 PM 341 views 0 times favorited 8 replies Add to Favorites Watch
View woodworm1962's profile
woodworm1962
145 posts in 124 days
02-28-2018 11:53 PM
I have been spraying a ton of Lacquer lately and am seeing little green men and pink elephants and talking to the appliances because I wear no breathing protection. I spray and run out of the shop.
Time for a mask/respirator.
Any suggestions. I normally do not have beard so…
PS I usually use brushing Lacquer thinned out with one to one Lacquer and lacquer thinner.
-- No one likes the truth...
8 replies so far
View pintodeluxe's profile
pintodeluxe
5702 posts in 2836 days
#1 posted 03-01-2018 12:01 AM
Many masks will work, just get cartridges rated for organic vapors. The cartridges for dust won’t protect you from the fumes.
View clin's profile
clin
849 posts in 1019 days
#2 posted 03-01-2018 12:06 AM
I have a 3M 7500 series respirator that I mostly use for particulate filtering. But, I did use the organic vapor cartridges with it once using the solvent based contact cement when laminating a counter top.
I put it on and went to work. I could not smell anything and did not get light headed, nothing. I figured this cement must not be so bad. Finished up and took the respirator off before leaving the shop. I was getting lightheaded before I reached the door. I was amazed how well those cartridges worked and will continue to use them anytime I’m working with solvents for any length of time.
-- Clin
View Rich's profile (online now)
Rich
2963 posts in 612 days
#3 posted 03-01-2018 12:45 AM
The green men and pink elephants are real. Seeing rainbow unicorns is an indication you’re losing it however.
Seriously, +1 on the 3M organic vapor mask. Like Clin says, you can get the pink P100 filters for particulates to use when you’re sanding, etc. Store the vapor filters in a ziploc when you’re not using them and they last longer.
View jbay's profile
jbay
2333 posts in 922 days
#4 posted 03-01-2018 12:50 AM
The green men and pink elephants are real. Seeing rainbow unicorns is an indication you re losing it however.
Seriously, +1 on the 3M organic vapor mask. Like Clin says, you can get the pink P100 filters for particulates to use when you re sanding, etc. Store the vapor filters in a ziploc when you re not using them and they last longer.
- Rich
Shouldn’t he be using brushing sanding sealer first?
View AlaskaGuy's profile
AlaskaGuy
4204 posts in 2332 days
#5 posted 03-01-2018 01:34 AM
The little green men aren’t too serious, but, the the pink elephants means it’s too late for you. Sorry dude.
View bbasiaga's profile
bbasiaga
1234 posts in 2018 days
#6 posted 03-01-2018 01:36 AM
That pink elephant is a jerk. Keep one eye on that guy….
Agreed the 3m half mask ones you buy at home depot are great. I has a similar experience to Clin with a 2 part epoxy i was using.
Brian
Rich
#7 posted 03-01-2018 01:59 AM
Shouldn t he be using brushing sanding sealer first?
- jbay
That is so last month. I’ve moved on — to spray pre-cat heavy bodied sanding sealer. And don’t forget the compressed air spray head cleaning trick.
View jbay's profile
jbay
#8 posted 03-01-2018 02:09 AM
- jbay
That is so last month. I ve moved on — to spray pre-cat heavy bodied sanding sealer. And don t forget the compressed air spray head cleaning trick.
- Rich
lol
