HOW I FIXED DW-788 ARM
« back to Scrollsawing forum
Forum topic by GR8HUNTER posted 02-28-2018 08:49 PM 840 views 0 times favorited 8 replies Add to Favorites Watch
View GR8HUNTER's profile
GR8HUNTER
5102 posts in 912 days
02-28-2018 08:49 PM
Topic tags/keywords: scroll saw dw-788 lift arm
STARTED BY FASTENING A 1 INCH WIDE 1/8 INCH THICK PIECE OF ALUMINUM TO SAW WITH 2 – 3” 6MM BOLTS 1.19 CENTS BOLTS 7.72 FOR ALUM.
THEN FOR FRONT I GOT 1 INCH 5MM WITH WASHER AND BUSHING .37 CENTS BOLT .74 CENTS BUSHING
NOW ALL I HAVE TO DO IS PUSH ARM UP AND PUSH IN ALUM.
THEN TO RELEASE IT JUST PUSH ARM UP AND ALUM SPRINGS BACK OUT
SO LETS SAY 12.00 TOTAL WORKS LIKE A CHARM I AM A HAPPY CAMPER :<))
8 replies so far
View Dutchy's profile
Dutchy
3147 posts in 2368 days
#1 posted 02-28-2018 09:05 PM
How simple it can be.
-- https://dutchypatterns.com/
View LittleBlackDuck's profile
LittleBlackDuck
2079 posts in 1020 days
#2 posted 02-28-2018 09:48 PM
Neat Idea!
Hmmm… I have the aluminium, the bolts, washers and a functional right thumb… so all I have to do is buy a new DeWalt scroll saw and I’ll have saved $12.
View crowie's profile
crowie
2733 posts in 2150 days
#3 posted 02-28-2018 09:53 PM
You’d make a damn good bush mechanic downunder Tony…well done!
-- Lifes good, Enjoy each new day...... Cheers from "On Top DownUnder" Crowie
View lew's profile
lew
12427 posts in 3954 days
#4 posted 02-28-2018 10:29 PM
That’s really cool and inexpensive, too!
LittleBlackDuck
#5 posted 02-28-2018 10:35 PM
You d make a damn good bush mechanic downunder Tony…well done!
- crowie
Yup.. that ‘luminum bar will take the spring out of our wild ‘roos.
MrUnix
7042 posts in 2398 days
#6 posted 02-28-2018 10:45 PM
I don’t have that saw, so I really have no idea – what problem is this modification solving?
GR8HUNTER
#7 posted 03-01-2018 12:16 AM
the arm on the DW-788 does not stay up on its own …so you have to put a block of wood under it or come up with this solution which is better then a block of wood that’s in the way makes it tons easier to change blade holes :<))
View Kelster58's profile
Kelster58
670 posts in 739 days
#8 posted 03-01-2018 01:02 AM
There’s some ten cent engineering….....Looks good, you’re teaching us all a few tricks!
-- K. Stone “Tell me and I forget, teach me and I may remember, involve me and I learn.” ― Benjamin Franklin
