Newbie with dado/rabbet question...
Forum topic by ringore posted 04-19-2011 03:14 AM 2524 views 0 times favorited 5 replies Add to Favorites Watch
View ringore's profile
ringore
24 posts in 2833 days
04-19-2011 03:14 AM
Topic tags/keywords: design dado rabbet
How deep should dado/rabbets be in a side panel of 3/4” plywood bookshelf? I wasn’t sure if there is a rule of thumb to follow when determining the depth of the cut.
-- "I'm a classic overachieving underachiever" - Phil Newcomb
5 replies so far
View mvflaim's profile
mvflaim
189 posts in 3325 days
#1 posted 04-19-2011 03:18 AM
3/8”. rule of thumb is the depth of the dado is half the thickness of the side.
View rance's profile
rance
4267 posts in 3394 days
#2 posted 04-19-2011 03:28 AM
I always teach 1/3 the thickness. I’d be interested to see what A1Jim does on his. A tie breaker? :)
View JasonWagner's profile
JasonWagner
527 posts in 3414 days
#3 posted 04-19-2011 03:42 AM
Yeah, i’ve always done about half the thickness…are these dados to hold the shelves?
-- some day I hope to have enough clamps to need a clamp cart!
View bubinga's profile
bubinga
861 posts in 2902 days
#4 posted 04-19-2011 04:08 AM
I agree with ,,rance
a quarter inch deep dado (in three-quarter inch stock )will hold the shelves fine, and not weaken the sides
But once it is glued up, it probably doesn’t matter
The two bookshelves I built the dado’s were, one third the thickness of the sides
-- E J ------- Always Keep a Firm Grip on Your Tool
View devann's profile
devann
2246 posts in 2926 days
#5 posted 04-19-2011 04:10 AM
I’m in the 1/3 camp. I use a router with a template bit and jig. Rout back to front, turn off router at end of cut and remove. Do not back out, the joint won’t be has tight. I don’t cut all the way across the sides because I round over the front edge of the bookshelf.
